Question about Samsung SF Office Equipment & Supplies
Replace cartridge message after new cartridge installed
I replaced the printer cartridge but the replace cartridge message does not go away. I've switched it on and off, took the cartridge out and put it back in etc but nothing. Won't even allow me to print a fax report.
    Sergeant:
  • 241 Answers
If the cartridge you are installing is a refilled/remanufactured cartridge it may be that you need to indicate to the printer that it is a used cartridge and not a new one upon installation. This is because the cartridge works on a basis of counting pages and calculating page coverage to estimate how full it is. It has no way of telling that it has been refilled and can indicate to the printer that it is running low and needs replacing.
This message could however be the result of something as simple as the printer not being able to recognise the cartridge. In which case I would recommend wiping the contacts on the cartridge with a piece of kitchen tissue and re-installing. if this fails to helps I would recommend replacing the ink cartridge.
Posted on Oct 31, 2012
  • 214 Answers
SOURCE: canon Pixma MP 780
This may seem to be a stupid question but, is it the right cartridge?
Is it a genuine Canon cartridge or an aftermarket replacement that "suits" your printer? If the latter, try getting a genuine Canon cartridge and install that and see if you get the same error message.
If you still get the same message, take it to a repairer and get them to check it out for you.
Good luck.
Posted on Apr 07, 2008
Arius
  • 446 Answers
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Posted on Aug 16, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
don_farr
  • 1018 Answers
SOURCE: lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Posted on May 10, 2009
  • 65 Answers
SOURCE: My HP M1120 MFP laser printer reports a 'no print
There would have beena jam on the printer.. Just take out the paper and then reseat the Cartridge to have it worked...
It worked for me..
Posted on Nov 18, 2010
How can I get "Replace Toner Cartridge message to go away?
Pressing the Clear/Back button when front cover is opened. press the arrow down key to show the appropriate toner, then press 1 to reset the bias, close front cover.
Jul 30, 2014 | Brother MFC-9010CN - 17 PPM Multifunction...
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a fax in memory how can I retrieve it
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Oct 31, 2011 | Lexmark X6570 InkJet Printer
How do I print faxes in the memory of Lexmark X6650 all-in-one-printer ? Is there a "tools" item in the setup menu ?
Sep 15, 2011 | Lexmark C533DN InkJet Printer
I am unable to retrieve fax from memory, on the Fax Setup menu no reference to faxes in memory. I have a Lexmark 6650. When the fax wa sent it said "printing" but nothing came out
Aug 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Error message 88 Replace magenta
Magenta is one of the colors of toner you need for it to run. You will need to install a new color cartridge.
Mar 01, 2011 | Lexmark C534dn Color Laser Printer
Install Toner Msg
I had the same problem when I had the cartridges refilled. Aparently some electronic part inside the cartridge needs replacing when a cartridge has been re-filled. If its a new cartridge i do not know the answer.
Cheers,
David J.
Jul 10, 2008 | Samsung CLP-510 Laser Printer
"Replace Drum" message won't go away
pls install the drump properly if it is in correct position that mean printer need to be service.
Sep 27, 2007 | Panasonic KX-FLB801 All-In-One Laser...
New ink cartridge problem
pleaz change the same original cartridges
Apr 19, 2007 | HP OfficeJet V40xi InkJet Printer
216 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
