Question about Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
Philips HTS3450 worked well in one room. Moved to another room and it worked well for few hours. Now have video but no sound. Subwoofer power light is on. Can control player but when I use set up menu, speaker volume is greyed out.
  • solva Jan 17, 2009
    My Philips LX3000D has exactley the same problem,Picture but no sound.
    I found that the small radio fuses on the pcb had blown, But after replacing them for new fuses of the same rating,they blew again as soon as i swiched it on.
    Can anyone Help with a solution to this problem ?
  • pkrrjibson Jan 23, 2009
    We also have the Philips HTS3450 and have no audio. My husband called Philips and was told they have never heard of that problem.
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Posted on Jan 29, 2009
I have the home theater system model HTS3440/37. I've had this for a couple of years, and now all of a sudden, it won't read any discs. It comes up after a couple of seconds and says "No Disc"....
Well, let's see.
A) A whole used HTS3440 is available on eBay for $102 delivered.
http://cgi.ebay.com/Philips-HTS-3440-Home-Theater-System-/150532939141?pt=Home_Theater_in_a_Box&hash=item230c765d85
B) A compatible HTS3450 base unit goes for $79 delivered...
http://cgi.ebay.com/Philips-HTS3450-HomeTheater-Receiver-HTS3450-37-/360338243552?pt=Home_Theater_in_a_Box&hash=item53e5d53fe0
C) Connect a new or existing outboard DVD/BluRay player to it.
Proprietary connectors usually imply proprietary function. Home Theater in a Box runs that way and are typically Not Economically Repairable.
Though it may be possible to construct cabling that adapts 'normal' standardized audio to your HTIB speakers, is it really worth it?
I'd got with option C as it would be a better investment in equipment with longevity and forward compatibility.
Feb 05, 2011 | Philips HTS3440/37 System
Hi I have a Philips HTS3450 system but lost the Subwoofer, Is there a way that I can connect the Subwoofer connection to my Panasonic Home theator system to get the sound? Thanks in advance
I'm not sure what you mean by "connecting the Subwoofer connection to my Panasonic Home Theater System"
If you want to watch something on the Philips and send the audio to your Panasonic Home Theater you can buy a VGA to AV Adapter Cable. Just connect it to the back of the Philips HTS3450, get an AV cable (red,white,yellow) and run it to the Panasonic.
I recommend buying it here: http://www.buy.com/retail/product.asp?sku=212966742
Aug 11, 2010 | Philips HTS3450 System
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
Pinout for 15 pin audio connector on Philips
1=control (I assume this is some kind of digital signal to turn the amp on and off...?)
2=nc (no connection)
3=nc
4=centre
5=centre ground
6=digital ground (possibly not needed if you're not hooking into the sub...?)
7=subwoofer
8=sub ground
9=nc
10=left ground
11=left front
12=right front
13=right ground
14=right rear
15=left rear
A full service manual for the HTS3345 is available at http://www.scribd.com/doc/37538958/Philips-HTS3455
Apr 14, 2010 | Philips HTS3450 System
Philips HTS3450, sound cutting on and off during DVD playback?
If the Video portion of the DVD is running smoothly and the audio is cutting out, you've got an internal problem. You can try running a Laser Lens cleaner thru it, you can get them at just about any retail store, get one that uses fluid, 15-20. Good maintanance habit, run it thru a couple times then try a DVD. If it still has an issue, it's more cost effective to replace it than repair it, a repair would run 100-150 on average. Hope this helps
Jun 23, 2009 | Philips HTS3450 System
Philips hts3450 have video but no sound.
It seems your device is thinking it has no speakers connected, reconnect teh cable between the device and the subwoofer and make sure it is connected properly.Als chekc all speakercables if they are connected properly and correct (+ on + and - on -).
Jan 03, 2009 | Philips HTS3450 System
Philips home theater system
Make sure there is a video cable of some type running from the back of the Philips to the television, and make sure the TV is on the correct source channel. Make sure the home theater system is in disc mode.
-Tha Mp3 Doctor
Dec 08, 2008 | Philips HTS3450 System
Proprietary speaker terminators - Clip them?
Don't waste effort with phillips take system back get better one then put the effort to make the perfect quality sound dynamics in your room, none of our phillips systems work after 8 months and warranty work is non existant.......sorry
Jan 12, 2008 | Philips HTS3450 System
Philips HTS3450 System Logo
495 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
