Question about Kenmore 22622 Top Load Washer
Washing machine Machine makes whinning noise in agitation cycle,in all modes,heavy,normal and delicate.
  • 530 Answers
Sounds like you have something stuck in your pump. I know it sounds strange that it more than likly does not make any noise in the drain. But i garrenty you there is a problem within your pump. Tilt the unit back and prop against the wall. DO NOT TIP ALL THE WAY OVER! you will see the pump it has 2 clips unclip them take the 2 hoses off and remove the pump. water will come out so be prepaired with towels. look inside the pump there will either be money in there or a bra wire. MAKE SURE YOU TURN THE POWER OFF FIRST. Let me know how it goes
Posted on Jan 07, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
Washing machine will not start the wash cycle after filling with water. I have tried normal, delicate, and heavy duty cycles.
Not sure what model you are referring to, but in general, it sounds like a problem with the timer switch or if it's all electronic, then it will be in the control board.
If I had the model number I could be of more assistance.
May 27, 2011 | Kenmore Washing Machines
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Oct 23, 2008 | Washing Machines
Washing machine
Sounds like a gearcase but before you do I would look at the belt and motor.
Oct 11, 2007 | Admiral AAV7000A
Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Nov 19, 2006 | Kenmore 24902 Top Load Washer
Kenmore 22622 Top Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
