Question about Whirlpool Washing Machines
Whirlpool WFS1275CD service manual - Whirlpool Washing Machines
Whirlpool service manuals
This could be the door switch unless it is totally without any power. First thing is to unplug it for a couple of minutes. Then try again. If that does not work, remove the panel under the door and look for an envelope to locate the tech sheet on it. It has all the tests etc.
Sep 08, 2014 | Washing Machines
Whirlpool 6th sense 7.5kg washing machine. My machine has lost all signs of power. Ive checked the power points, cleared the lint catchment and taken the top panel off but no signs of cables burnt or...
you need to check if power is going all the way to the board. The only way to do this is to trace the power cable to the board. When you have located now comes the tricky part. You will need a current tester. You will need to put the probes of the tester into the power cable (one on each side) and switch the power on to the machine. I would only recommend doing this if you are very competent in electrics. If you do this and find a full 230 going to this plug then it means you're board is dead and its new machine time if you are not covered by your parts guarantee. If there is no power going to the plug then you need to recheck back down the line
Oct 16, 2013 | Washing Machines
Just bought a new whirlpool WFS1275CD. The hose is connected correctly and seems to be drawing up water to the machine, but it is not getting into the machine. Am getting a Water Tap Closed light, but even...
I know your machine is new BUT it is worth carrying out the (pre-typed) checks below! For 'hot and cold' read 'cold' only as necessary ;-0)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, contact the vendor/service desk!
This is a new washer and I assume under guarantee/warantee?!!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 12, 2011 | Washing Machines
I have just purchased the WFS1275CD Whirlpool front loader and found that it periodically stops and a message comes up to say the tap is closed (hot water - but there is no hot water outlet on the machine)...
Sorry but, because of the confusing message, I am unsure- is this is a cold fill only washer- or a hot and cold fill but with a cold water feed only (into a 'Y' piece)?
Here are my pre-typed notes on what I call 'poor cold fill'!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
John C
Aug 01, 2011 | Washing Machines
Washing Machines Logo
440 people viewed this question
Dan Webster
Dan Webster
Sal De
