Question about Maytag Neptune MAH7500A Front Load Washer
Soap or lint residue on washed clothes - Maytag Neptune MAH7500A Front Load Washer
Cleaned soap dipenser out
Posted on Jan 05, 2009
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
Have residue on most to all clothes. i thought it was a water softner problem but that is now fixed. any ideas?
Residue is almost always soap related.
1: Soap goes in the washer first, then clothes. The other way around leaves soap on clothes.
2: switch to concentrated liquid soap. This blends better with cold water.
3: Dry soap has cardboard fillers. Cheaper soap has more fillers. Try a better soap brand.
4: The washer may have build up inside and may need to be cleaned out. (not likely as this clears up real fast)
Apr 03, 2010 | Washing Machines
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
Feb 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior...
the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Jul 01, 2008 | Maytag Washing Machines
Soap residue on clothes from washing machine
I have the same problem. Can't get soap out my clothes. I have a Sears Kenmore frontload washer. It seems to work fine but something isn't right. Repair man came few days ago & said NOT to use the brands they say "For ALL HE Washers" ALL being the key word. Only use the ones that only say HE. I changed back to Gain instead of Sam's brand, but I still can't get soap out. I really don't think its the detergent. I washed my daughters towels & had soap in clothes after complete full wash was done. I'm lost & have no idea what the problem is or how long its being going on before I noticed.
Dec 15, 2007 | Washing Machines
Lint or soap residue
Sounds more like a build-up of particles that may very well be in the water supply. There is something that you can try to get rid of these particles.
1. With the machine empty start it in normal eash mode and let it fill. Add 1/2 cup bleach to the water and let the machine run completely through the wash cycle. This will help remove any unseen stains or build-up.
2. When the machine drains and begins to refill on the next cycle, add 1/2-1 cup of white vinegar and again, let the machine finish its' cycle.
3. Run the machine through the wash cycle one more time to remove any vinegar that may have been left behind.
This is not a guaranteed method but I have had some success.
Dec 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Maytag Neptune MAH7500A Front Load Washer Logo
369 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
