Question about Samsung R530 Notebook
Laptop is can not show thw charger power light
  • max carson
    max carson Oct 31, 2012
    A bit confusing, wouldn't you say?
    Novelist:
    Champion:
  • 233 Answers
Maybe your charger is malfuction. Either you can borrow a same charger or puchase a new charger to check. If it can't change the situation, another possible cause is your dc jack is dead or loose. Go to repair it or do it by yourself.
If you want to purchase a new charger, I recommend the following one for you:
samsung laptop charger
Posted on Nov 01, 2012
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
Acer aspire one shows no power light when charger is plugged in...charger shows 6 volts
Hello, I'll do my best to help you out.
The Acer One have one weird problem, and that is of the mother board. "Naaahh, how can that be?" you may ask. The BIOS in the motherboard have a bug, in which in a certain amount of time it will shut down the Netbook and it will give you the impression that it's dead. But it isn't. As you posted it here, the power supply is working fine. I'm not sure if it's still available, but there is a patch, which it will allow you to flash and fix the Netbook. Now, I'm not able to share the patch with you just because there is no detIl on your Netbook, for example, I own an Acer One ZG5. If yours happen to be the same exact model, let me know and I'll do everything I can to share the patch with you and how to flash it.
Mar 24, 2014 | Acer Aspire One PC Notebook
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Laptop can't pw on wif charger or batt *light go off on charger*
does the machine work at all? at best its faulty charger , I recall a laptop sometime ago I worked on had a fight with what looked like , 3 pints of milk and a cup of coffee showed same syptoms, could be faulty MOBO
hope this helps
Jun 10, 2009 | Dell Inspiron 6400 Notebook
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
My charger shows greeh light untill i plug it in to laptop
It sounds like the power distribution circuit on your motherboard is shorting out your AC adaptor. The motherboard will need to be replaced or repaired.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell C-800/840/INS 8200 CHARGER BOARD...
Samsung R530 Notebook Logo
82 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
