Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Movie Formats To Work With Xbox 360
By Phage on May 17, 2007
What file formats do my movie files need to be to be able to run on the Xbox 360 so that I can store them and watch them from the hard drive?
Same Problem
Apr 05, 2009
-   xbox 360 won't play a movie file from flash drive -   supple21
Solution #1
posted on May 26, 2007
Somewhat Helpful)
STUART360
Rank: Wiz
Rating: 87%, 64 votes
As you may have heard, with the Xbox 360 Flash Fall 2006 System Update they are adding support for WMV video playback from new sources. Videos can be streamed from a PC running Windows Media Connect, Windows Media Player 11, or the new Zune client player, and can also be played from Optical Disc and most USB mass storage devices. For all these sources, only the WMV video file format and codecs are supported.
How do I know if a video file will work on the Xbox 360?
Currently only the Windows Media Video (WMV) file format and codecs are supported. If you have a file with a ?.wmv? extension, then the odds are pretty good that it will work. Technical details on the types of files we support can be found at the end of this post, but the easiest way to find out if a file will work or not is to just try it. Hopefully after you click play the video will show up on your display, but if the content is not supported you will simply get an ?Unplayable Content? message blade from the side of the screen and then be returned to the Video blade.
How do I create videos that will play on my Xbox 360?
Windows Movie Maker, a standard feature of Windows XPSP2, will output WMV video files compatible with the Xbox 360 console. Either use the default settings when you finish a movie and click ?Save to my computer,? or just make sure that the output video format you select shows the file type as ?Windows Media Video (WMV).?
Videos will usually look best when they are closest to the original resolution that they were created with. Try to create video files at least 360 pixels high in vertical resolution in order to minimize content upscaling on the console.
If you decide you want finer control of the output video file format, download a version of Windows Media Encoder (http://www.microsoft.com/windows/windowsmedia/) and then start encoding away. Optimal size and bitrate settings will vary depending on the source material you are encoding. As a general guideline though, 1.5 Mbps is a typical bitrate that should be suitable for most standard definition content, and 8 Mbps is a common bitrate for high definition content.
Can I get more technical details about the kinds of files you support?
WMV video files with the extension ?.wmv? are stored in a generic file container format known as ASF. ASF files can contain many different types of codecs within them. Xbox 360 supports most common WMV video codecs, as seen in the following chart:
Supported Video Codecs:
Name
FourCC
Windows Media Video 7
WMV1
Windows Media Video 8
WMV2
Windows Media Video 9
WMV3
Windows Media Video 9 Advanced Profile
WVC1
There are some files with ?.wmv? extension that may play on a PC, but are unsupported on the Xbox 360 console. Windows Media Screen, Windows Media 9 Image (Photostory), and some older Microsoft codecs are unsupported, as seen in the following chart:
Unsupported Codecs:
Name
FourCC
Microsoft MPEG-4 Video Codec V3
MP43
Microsoft MPEG-4 Video Codec V2
MP42
Microsoft MPEG-4 Video Codec V1
MP41
Windows Media Screen V9
MSS2
Windows Media Screen V7
MSS1
Windows Media Video 9 Image
WMVP
Windows Media Video 9 Image v2
WVP2
ISO MPEG-4 Video V1
MP4S
Anamorphic content with nonsquare pixels is currently unsupported on Xbox 360 console, and will be displayed as if the pixels were square. If you want to play such content on your console, it is recommended that you re-encode the content in a square pixel format.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
what are the wep64 codes and where can i find them cant get connected to my home hub
Answer
evry time im playin a game it comes up on da top of da screen connection interupted and then the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
