Question about Philips HTS3450 System
Philips hts3450 have video but no sound.
Wored great for several months on one room of the house. Moved it to another room worked great for about two hours then now sound. Subwoofer light is on, have video from dvd player; but now sound from any item. When I go to sound menu, speaker volume is greyed out. Thank you
    Scholar:
  • 144 Answers
It seems your device is thinking it has no speakers connected, reconnect teh cable between the device and the subwoofer and make sure it is connected properly.Als chekc all speakercables if they are connected properly and correct (+ on + and - on -).
Posted on Jan 29, 2009
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
I have a philips surround system model # HTS3450/37 and my subwoofer is out and i cant hear anything through my system. How do i check what is out on my subwoofer?
Hi
I have a Philips HTS3450 system but lost the Subwoofer, Is there a way that I can connect the Subwoofer connection to my Panasonic Home theator system to get the sound?
Thanks
in advance
Jan 01, 2010 | Philips HTS3450 System
Dvd player works, but no sound from any speakers
yes, company will charge you, but the best suggestion is to get repaired from the company person.
The normal problems are bad contact of speaker wires and settings of sound from the sound menu. I think you are a genius guy, so you might have checked such things, so now its better to give it to PHILIPS SERVICE CENTRE.
Apr 23, 2009 | Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
Installing help
check on www.philips.com and search for HTS3450, all setup details are available there.
Jan 02, 2009 | Philips HTS3450 System
Philips HTS3450 sound problem
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jun 09, 2008 | Philips HTS3450 System
Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
Apr 06, 2008 | Philips HTS3450 System
Buzzing noise
If the sound goes out completely, try hitting the mute button (to mute it) and then hit it again (to un-mute). I've found that this work-around typically gets it working, at least.
Jan 03, 2008 | Philips HTS3450 System
Second zone not working
This amp allows you to pick a secondary source for those other rooms. Did you by chance accidentally change it from the "SOURCE" designation that makes room 2 listen to same thing as room 1? Just a thought.
Dec 04, 2007 | Denon AVR-3801 Receiver
Philips HTS3450 System Logo
314 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
