Question about Gbc HeatSeal H425 Laminator
Gbc heatseal h535 turbo
We have something jammed in the laminator. How do we open the top to get it out please?
3 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
. How do i fix my fellowes Mars A3 laminator it has jammed
Let it cool off for a while, then try reversing it. If it won't run it would have to be taken apart to clear the jam - a messy job! Fellowes does not usually consider these to be repairable but I would call them on their Toll-Free number to see what they can offer (800) 955-0959
Jul 01, 2014 | Gbc HeatSeal H425 Laminator
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
I have a gbc heatseal h535 turbo laminator that jams, stops rolling, and shuts off randomly.
I had the same problem. It's prob the optical chopper/encoder wheel on the motor shaft that wobbled loose and scraped on the sensor until plastic filings plugged up the holes. remove cover and check the "u" type sensor the chopper wheel runs in. Mine was really crammed full of plastic so I had to take it it off and pick it out with a blade. when you reinstall make sure wheel runs between sensor with no scraping.
Mar 18, 2010 | Quartet gbc RDS1819 Shredder
Gbc HeatSeal H425 Laminator Logo
132 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
