Question about JVC HD-56G786 56" Rear Projection HDTV
Line on my 56g786
Hello, I am have this vertical line going across the entire height of my jvc 56g786 dila TV. It looks like its about 2 pixels wide. Does anyone know what is wrong with it? Do I need to get the light engine replaced? thanks, Terence
    Scholar:
  • 150 Answers
Can you see lines over your menus? if so, replace light engine.
Posted on Jul 11, 2007
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
How do I fix dark lines across the top of my tv screen? It's a JVC lt37x688
Sounds like vertical height problem. Check and replace all the electrolytic capacitors [5 or 6 of it]; at its vertical scan output section circuit. Replace all of it at one time. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 04, 2014 | Televison & Video
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
We have a 56 inch JVC HD-56G786 backlit projector TV and the screen just completely pixelated while watching cable. I turned it off and back on and now even it has a green screen with staticy vertical...
Some of these had problems where the micro for the Dlp gets confused, they have a jig to connect the set to a computer and download two updates on sd cards---it may or may not cure this but this is a shop repair.
Aug 29, 2012 | JVC HD-56G786 56" Rear Projection HDTV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Top of screen is stretched
There are capacitors in the vertical circuit that can cause this problem. You may be able to find these capacitors by using a hair dryer pointed to the suspected bad cap and then when the problem happens you can spry a little cooling spray on it to see if the problem clears up. The vertical output IC could be going bad but this can be checked the same way. if you have no TV solid state repair experience, play it safe and take this set into a local repair depot. Good Luck
Mar 17, 2007 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
JVC HD-56G786 56" Rear Projection HDTV Logo
235 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
