Question about VIA Computers & Internet
Dead won't power on
    Sergeant:
  • 238 Answers
First thing to check is the power supply. If you were having to push the power switch several times to get it to turn on before this, it is almost certain to be the power supply. If it is a new build, then try removing the motherboard from the case and rest it on a towel or some good insulator and try powering it on with just the cpu, heatsink and ram.
Posted on Oct 31, 2012
1992 Dodge Stealth SOHC - no problems, running great, then I replaced the distributor (forgot to mark it) & now the car won't start up. It'll turn over, even got it to start once but won't...
put number 1 cylinder at top dead center and drop in distributor so the rotor points to number 1 on cap. may have to try several times as gear moves when lowering dist.
Sep 07, 2013 | Cars & Trucks
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
The battery seems to be dead but it does respond promptly to the jump start. However when it drives the van can only move at 5-10mph
You say the battery seems dead
I suggest that you test it,you should also
know if it is at least 5 years old & would expect it to go dead
That said, those things you need to know before you
ever attempt to jump a battery
If it isn't capable of taking a charge,then your
basically creating an unsafe act & bad things
could happen to that battery & you
If the battery is dead & the vehicle is running
on the alternator,then the electronics won't work
& you go 10 mph or not at all or worst.
The lack of power could be any number of things
Work on the battery issues,then continue on
May 29, 2012 | 2004 Nissan Quest
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
Dec 10, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
Stand by button blinks 9 times when power button is pushed & it won't turn on
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem, and do take care in handling the fault, because it contains high voltages....
Jun 18, 2011 | Televison & Video
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Computers & Internet Logo
219 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
