Question about Philips Televison & Video
42pf75200/10 no sound when i plug in hd equipment
    Top Expert:
  • Philips Master
  • 14,553 Answers
Unplug and recheck your connections---HDMI or Component? HDMI is prone to this kind of issue.
Posted on Oct 31, 2012
When a overhead light is switched on,the tv sound goes and picture breaks up
sounds like distortion from this overhead light you are turning on.
try TV else where in another room for example.. see if it reacts to other equipment being turned on
Jun 02, 2013 | Panasonic TX-L32C4B 32-inch Widescreen HD...
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
http://hd.sky.com/hd-television-equipment/hd-set-top-box/
http://hd.sky.com/hd-television-equipment/input-output-connections/
http://www.ehow.com/how_5890852_convert-hdmi-rca.html
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Mar 11, 2011 | Sony DAV-S300 System
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Have sound but no picture
Are you missing the picture on HD channels?
If so, you might be using a none HD ready equipment
Feb 03, 2010 | Televison & Video
My hd cable box works great in all of the video in connections on the tv, but my dvd player, hd camera do not work when I plug them in, the picture is like it is scrambled, but if I plug the cable box in...
Are you connecting these devices to the ColorStream inputs?
If so you will need to set the output settings on the DVD player or your camera to 480i. You have an HD capable TV but it is old technology and is not capable of handling the signal levels produced by HD equipment these days.
Look at the menu options on your equipment and most of them have the ability to put out the lower level signal or just hook them up using the standard yellow/red/white inputs. Hope this helped.
Good Luck..
Dec 10, 2009 | Toshiba 36HF72 36" TV
Hd radio
hd ready means you need an optional adapter to recieve HD radio broadcasts (digital reception will be without static, and often have sidebands extra music on the same channel) provided there are broadcasters in your area transmitting HD signals most major cities have many HD providers. And many smaller areas now too.
Jun 08, 2008 | JVC AM FM CD DET FACE CAR STEREO
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Set-up problem with sound and speakers
I sent this TX-SR605 system to an authorized dealer for repair. It seems like it is a very simply problem - the internal set-up mic jacket closed circuit, so the system think the set-up mic is always plugged in (even when physically unplugged it, the system still detect plugged in). And it enters the automatic speaker setup and never quit.
Now I have the receiver back home and tested it. Everything worked O.K. now. It is a pity that this new-bought equipment (just one month) need repair for just a small action of plug in a mic ( I swear I plugged it in very tenderly). It is shame for such a unreliable performance happened on brand name like ONKYO. How can you be confident for an equipment failure in one month.
Dec 25, 2007 | Onkyo TX-SR605 Receiver
Loss of sound when I go to HD mode of tv.
Unplug the Moto box and plug back in after 1 min, as far as the codes, which remote cable/ tv? Cable remotes vary so much you will probably have to call your provider to have them walk you through programming.
Jul 16, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Connections
Follow these; 1-Get an Xbox 360 HD cable (see the picture1 below) 2-Connect the red and white plugs to one of your amplifier's empty inputs. 3-Connect the VGA plug to the LCD directly By following these instructions you'll be able to get surround sound from your amplifier as long as you keep it turned on. 2nd solution could be that; (if you have some other equipments connected to the amplifier such as dvd, cd, etc.) 1-Get the above-mentioned HD Cable and get a VGA to S-Video adapter (a small piece of equipment) 2-Do the same thing as mentioned in the 2nd above 3-This time, you're gonna select a VIDEO INPUT (video1, video2,etc.) on your amplifier's input selector. Affix the VGA plug of your HD cable to the S-Video adapter, and connect it to an empty S-Video input slot at the back side of the amp. 4-Get a simple RCA cable or a digital coax cable (up to you) to make a connection between the "monitor out" slot of the amp. and the "video in" slot of the LCD. It's important that which video input you've selected in your amp. to make this connection. For instance, if you choose "VIDEO 1", you will have to connect all plugs (Audio and Video) via VIDEO 1 slots. Good luck
Apr 17, 2007 | Pioneer VSX-D510 Receiver
Televison & Video Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
