Question about Yamaha DSP-AX1 10-Channel Amplifier
The sound of the LEFT MAIN Cannel disappears on my YAMAHA DSP AX-1
On start the sound of the LEFT MAIN cannel is missing in all modes and on A&B pair of speakers. After puting the volume to the max., the sound appears. Could this be due to aged capacitor or what? Any suggestions or experience on such problem?
  • Audio Azyl Dec 28, 2013
    There are two problems, first you have to solder socket with DSP board, or second relays are dirty, take off cover of relays and clean sandpaper for example 800 or 1000 and should resolve your problem
  • Yamaha Master
  • 5,151 Answers
The fact that sound appears at max volume means that it is getting past and through the pre-amp stage. So it would appear to be in the main power amp stage the problem. It would depend what drives the channel, but if it's transistor driven I would suspect one of them.
Posted on Mar 04, 2015
  • 317 Answers
SOURCE: loss of sound and memory settings
Just throw it away and buy a new one.
Posted on Oct 19, 2007
VOTIT
  • 2071 Answers
SOURCE: matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Posted on Jul 29, 2008
  • 236 Answers
SOURCE: Yamaha dsp-A1000 5 ch Amp
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Posted on Aug 04, 2008
SOURCE: yamaha dsp a1000 left channel cuts out sometimes in surround mode, sterio works fine
The easiest way is to buy the new part online and replace it - cost about $50US.
However, if you're up to it, this problem is fixable without the need to buy any parts. The selector switch has four sets of spring contacts which need to be bent slightly to increase the pressure on the pads against which they press, but it's a tedious job and not for the faint-hearted.
Here's what you need to do:
Open the case (6 screws) and also free up the front panel (9 screws).
You'll see that the switch consists of a PCB, an aluminium box and a motor. Remove the two screws holding it to the front bulkhead. take oyr the small "L" shaped circuit board that overlays it. A plastic pop-in holds the bottom of the switch PCB and the switch assembly can then be removed entirely.
Next you will need to remove the aluminium switch box from the PCB. Firstly de-solder all the connections which hold it in place. Now pull it clear.
Here is the MOST critical part of the job: inside the switch box you'll see four circular plastic wafers - these contain the contacts you need to fix and you'll need to bend the tangs which hold the shaft assembly onto the housing and then the tags which are holding the wafers in place. Your difficulty will be making sure that the wafers go back on the shaft with the rightr alignment and that the wafers go back in the same order.
Take some digital pictures while the wafers are still on the shaft with the orientation of the KNOB included - if you mess this up (I did) the job becomes horrible! Also, mark each wafer with a number 1-4 because there are three different kinds Once you are comfortable that you can replace the wafers in the proper rotary configration with respect to the shaft, remove them individually and pop out the gray plastic cores and bend the spring contacts upwards so that they will go back pressing more firmly against the pads. Now reassemble, and good luck!
Posted on Dec 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: I own a Dsp a 3090 yamaha receiver and the center
the manual
http://www.retrevo.com/support/Yamaha-DSP-A3090-Amps-manual/id/319ag815/t/2/
Posted on Jan 22, 2011
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
How do i type in a channel such as 7.1 ?
I don`t think you can, I have several channels, like 64-1 2 &3, and just have to let the cannel search find the first channel..ie;64, then I pressed remote up one channel, it went to 64-2 etc, hope this helped
Aug 24, 2011 | Polaroid 1720-7 Remote Control
I have a pair of Logitsch speakers,the left works properly while the right which is the main speaker works only in high volume.Any ideas how to fix it?
The problem is in the volume adjuster knob, the graphite layer of the resitor that it uses to adjust volume for the main speaker is damaged you must open the main speaker and replace it.
Jul 18, 2011 | Computers & Internet
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Amp wont work
Hi I have a Yamaha DSP 3090 Amp my right main Chanel is not working Amp goes off when i try to put the power on i think it goes on protction mode?after trying for 5to10 times it comes on, test mode all chanels work well not sure whats wrong ? can anyone slove my problem
Jan 02, 2010 | Audio Players & Recorders
Yamaha DSP-AX1 10-Channel Amplifier Logo
226 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
