Question about Konica Minolta Office Equipment & Supplies
Konica minolta r2 f1102-0 fan error - Konica Minolta Office Equipment & Supplies
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
jqsababa967
  • 145 Answers
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Posted on Dec 03, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
firecontrol7
  • 6161 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
  • 541 Answers
SOURCE: konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Posted on Dec 30, 2009
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub pro c6501 error c2304
Printer control board (PRCB)
Developing fan/1 (M45)
Developing fan/2 (M46)
Developing fan/3 (M64)
Check the above fans or its the board that controls them $$$$$$$$$$$
Apr 04, 2014 | Konica Minolta bizhub Office Equipment &...
How to solve error code c2351 in konica-minolta bizhub 164
Suction Fan motor failure fan located right side of machine from the front. Check vent can air and remove cover check fan and or replace worse case the board
Apr 30, 2013 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c252 error c-5351
Feb 22, 2013 | Konica Minolta bizhub Office Equipment &...
Product no of timing belt for konicaminolta r2 super
Konica Minolta drivers, manuals, and support information is located here.
Select the link on your left or use the dropdown menus to access information on Konica Minolta drivers,
manuals or customer care.
Download vista drivers, mac drivers, windows drivers, and linux drivers for Konica Minolta printers,
fax machines and other products. Find user manuals for accessories, office systems, print controllers,
printers, and print production systems.
Access the Konica Minolta customer care center including specific divisions:
National Customer Support Center (NCSC), Solutions Support and Development Group,
Solutions Engineering Center (SEC), National Account Administration, Technical Training Facility,
bizhub Image Center.
<a href=" http://www.allimagingsupplies.com/">konica minolta parts</a>
<a href=" http://www.allimagingsupplies.com/">minolta developer</a>
<a href=" http://www.allimagingsupplies.com/">minolta copier supplies</a>
Aug 31, 2012 | Konica Minolta Office Equipment & Supplies
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
I wont part list for konica minolta r2 super
It is here: http://minilab.com.ua/en/manuals/konica/r2/
Jan 24, 2011 | Office Equipment & Supplies
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
