Question about Nikon COOLPIX L2 Digital Camera
Lens Error My lens is stuck, might be jammed. But its half way out of the camera and when i turn it on i can hear it try to move but nothing happens. It only says lens error. I tried to move the lens by pulling it out but that didn't work. I need it fixed asap!
    Genius:
  • 2,985 Answers
Thus suggests a dirt entrapment. You will need a repair ship to look at it or go to Nikon website for this cameras model for Tech Support
Posted on May 17, 2007
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
My camera turns on , but shuts off right away. I just put in a new battery, but still have the same problem.
When a camera initializes, it checks certain functions, and extends the lens. When a lens is stuck, the gears driving it are usually either stuck or stripped. Dust or sand in the lens assembly can jam the len's gears. There are some things you can do try to fix this, unless the gear(s) are actually stripped, and in that case repair is needed. Here is a web page that explains the things you can try to free the lens, and get it working again.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog is about lens errors and stuck lens, so try the suggestions. They say about half the cameras can be fixed, trying their steps. If nothing works, the camera will have to be repaired. Make sure you get an estimate first, since the cost of repair can be sometimes be more than a new camera. Good luck, and hope this helps.
Jun 14, 2010 | Kodak EasyShare One Digital Camera
Camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Apr 23, 2010 | Nikon Coolpix S4000 Digital Camera
Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Jan 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
When I use the zoom button the lens moves three times, then I get a massage to turn the power button on and off!
Hello
This is a classic symptom of a broken or jammed lens assembly. The cost to repiar ranges from $100 to $175 to repiar so it might not be worth it.
I recommend you try the steps on the following blog as it works for about half of cases where this happens.
Kind Regards
Andrea
Dec 30, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
DSC-w70 stuck lens
there actually is a little gear inside that moves the lens and since you already opened it make sure the gear is there and moves. LOTS of problems with these cameras....
Jul 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Nikon COOLPIX L2 Digital Camera Logo
108 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
