Question about Miller Electrical Supplies
My miller bluestar 6000 welder generator won't weld
5 Suggested Answers
sal_kh_sab
  • 98 Answers
SOURCE: I have a Miller bluestar 2E I was useing it to run
probably the AVR card produced over-powering and then went down...try replacing it..
i hope i helped...send me an email for more details
Posted on Oct 11, 2009
  • 145 Answers
SOURCE: Ihave two miller Bluestars both have run but when
HAVE YOU CALLED MILLER
Posted on Jan 08, 2010
SOURCE: My lincoln welder/generator with onan engine will
Sounds like either it's low on oil or the oil pressure switch is bad.
Posted on Aug 28, 2010
precisionfen
SOURCE: miller bluestar 6000 welder/generator.
wont run
Posted on Sep 19, 2012
Miller bluestar 6000...generator works great...welding seems stuck on max amps...dial doesnt seem to change amp power...bogs engine..less than 150 hours...ideas???
could be a faulty power control swotch
I am inclined that the voltage regulator the controls the amp out put is faulty
Take it in for a specialist diagnosis to a welder repair shop
Nov 02, 2015 | Miller Welding Tools
My miller blue star 185 wont idle up when you start welding
Check your idle control module,
take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
I have miller 302 everything working good but stick weld not working
Make sure your both selector click ( AMPS range and then CURRENT)
Good luck .Patrick
Feb 17, 2014 | Miller Trailblazer 302 Welder Generator...
I have a Miller Bluestar 185. Will not start with key. Put a new battery in it and it pull starts fine but won't with elec start?
check if 12v go on solenoid of starter when you turn key to start,mesure 12 v on starter when you turn key to start
if voltage drop to few volt,wire or connection are bad
Oct 31, 2012 | Miller Welding Tools
Ranger8+ diesel will not weld or generate.
Check for proper placement of all springs & linkage on carb / throttle. One of those springs and/or linkage pieces is largely responsible for idling UP the engine so that it will be able to operate the welder & generator. If it won't idle up, it won't work right.
Aug 09, 2012 | Cars & Trucks
Electrical Supplies Logo
70 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
