Question about Acer Aspire 5002WLCi Notebook
Laptop screen not working
I have an acer laptop when i turn it on it lights up and the fan comes on but not the sounds like it's working because the fan goes in and out but no screen.
  • dodgeram71 Jan 04, 2009
    i have tried hooking up to a regular pc monitor but it just says no signal or something like that but doesn't work
    Problem Solver:
  • 5 Answers
Hi, I'm a laptop technician and if the screen is blank as in there is nothing showing on the screen at all (even when the laptop first starts up), but the laptop sounds like it is starting normally then the backlight or invertor for the laptop screen has probably failed. This is very common.
The easy way to check this is to plug the laptop into a normal PC monitor (if you can) via the monitor out port on the laptop - you may have to press Ctrl + F5 to get a display on the PC screen. If you can get the laptop to show an image on the PC screen then the main laptop itself is fine, and the problem is almost certainly a failed invertor or backlight.
Assuming you *could* see an image on the PC screen, you should then press Ctrl + F5 so that you *can't* see an image on the PC screen any more (this is very important). Next unplug the laptop from the PC monitor (if you did the above) and look VERY closely at the laptop screen. You will hopefully *just* make out a very, very feint and very dark image on the laptop screen. Bear in mind that you may need to re-boot the laptop to get a moving image that you can detect (like the Windows boot up screen for example). If you *can* see a very, very dark and feint image on the screen then the backlight has failed. If the screen is plain bright white or there is no image then the invertor has gone.
The invertor (or inverter as it is sometimes spelt) is a smaller circuit board that sits in the screen housing, the backlight is a very thin "flourescent" kind of tube light that is built into the screen itself. The invertor can be removed and replaced pretty easily by most competent people without much trouble (takes maybe 30-45 minutes to do). The backlight on the other hand is very hard to remove without damaging the screen itself and should only be attempted by a specialist laptop repair company.
Both the invertor and backlight parts are specific to the screen so you must get exactly the same to replace the faulty one with. Online auctions are a good place to get s/hand or new spares, just tap in the *exact* part number or laptop model number and you will usually find someone who has the bit you need.
I hope this helps.
Posted on Jan 04, 2009
Acer Aspire 9110 problem
Sounds like your video is bad or the laptop is not getting power from the ac adapter or battery. Make sure your ac adapter power cord is good.
Mar 27, 2012 | Computers & Internet
My screen is black and none of the lights except the batt light turns on but it sounds like the fan is on
I think the problem you are encountering has to do with the screen of your laptop.
Since the battery light turns on and the fan is also on then what you need to do is to go to the right computer store and get your screen replaced so your system would work perfectly
Jun 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer Aspire 4520, Will not turn on.
Feb 19, 2010 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Can't boot up my acer 290 notebook as the screen is
Hi,try making sure your heatsink is properly seated on your cpu chip with some cpu compound between them......I had a laptop that did the same & when i checked the cpu heatsink & fan i noticed the screws holding down the heatsink onto the chipset had come away so i applied some compound to the centre of yhe chip reseated the heatsink with longer screws & i also gave the heatsink & fan a good clean,put it all back together & it worked fine...goodluck
Jun 06, 2009 | Acer TravelMate 290 Notebook
Power lights come on the fan spins battery charges, but nothing else works
This sounds very much like a dead motherboard. I would suggest you get a professional to look at this or send it to acer. Visit thier site if you wish to. I would offer more help however laptop parts are expensive and tedious to replace.
Apr 21, 2009 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5002WLCi Notebook Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
