Question about Harmon Kardon Harman Kardon HK 3270 65W/CH Stereo Receiver Amplifier Radio Tuner
Harmon kardon hk3270 shuts off after only being on about 10 sec
Brand new looking receiver/amp inside & out. Does put out sound but not for very long about 10 sec. seems like its heating up even with nothing hooked up to it and volume down all the way. How can i fix this?
    Novelist:
    Champion:
  • 225 Answers
Disconnect speakers and wires. Bad wiring or defective speakers may be loading the amp down and causing the protection circuits inside to disconnect (no sound). If the HK is heating up (beyond what you perceive as normal) with no wires or speakers connected then you have a problem requiring expert repair.
Posted on Nov 02, 2012
Harmon/Kardon 3480
Beth, Protect mode in this unit indicates an open or short problem in one or more of the primary amp IC's in this unit. For a qualified shop this is a bit of a challenge sometimes disasembling the unit to put the amps in... The amps sit on a large aluminum heatsink and and each have their own set of feed resistors and caps. Each amp found to have failed should have their compliment of resistors and caps tested in orfer to prevent premature failure of the new amp(s)... If you're looking for a repair shop to do the job find someone who specializes in stereo receivers and amplifiers. If you're not sure where to begin you might call NESDA (National Electronic Service Dealer's Assn.). They can direct you to a member shop in your area... Hope this helps, Good Luck! Bill
Jun 01, 2007 | Harman Kardon HK 3480 Receiver
Receiver shuts off
Check the on/ off switch contacts, they may be burning out. Replace the switch or try spraying some contact cleaner into the switch from the inside.
Jan 10, 2013 | Harmon Kardon Harman Kardon Avr 645 7.1...
Amp shuts off on its own
Try getting a little fan , When I use to DJ same thing happened to me put a internal fan in it ... High volume will make it too hot.
Oct 07, 2012 | Harmon Kardon Harman Kardon Avr 645 7.1...
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Hi there, our amp is giving us very low sound output even when volume is turned up to maximum volume. We have been unable to find the remote and are wondering if the remote was turned right down would that...
I'd look at the front panel for the Mute Button and the Mute Indicator, but turn the volume down for any further investigations. If you can't hera the sound at 1/2 volume, it ain't there. No sense risking a sudden volume surge that will kill your speakers when you finally find the problem.
http://www.retrevo.com/support/Harman-Kardon-HK3270-Receivers-manual/id/386bh430/t/2/
Also check the T-Mon Indicator. If it;s on you have the Tape selcted for listening instead of a source.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
Dec 26, 2010 | Harman Kardon HK 3270
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Oct 28, 2007 | Harman Kardon AVR 25 MKII
Harmon Kardon Harman Kardon HK 3270 65W/CH Stereo Receiver Amplifier Radio Tuner Logo
222 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Lawrence Oravetz
 Grubhead
Grubhead
Ngoro
Ngoro
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
