Question about Samsung Remote Control Ah59-02131f Home Theater Dvd System Lcd Tv Ln32a330j1d
How do you change dvd region
Trying to play dvd that has a different region and it has an error about the rgion code
MakikiChris
  • 84 Answers
SOURCE: regional code change for a samsung ht-db120n
1) Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6) Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control. Your player is now region free. A word of caution is that you may have disc eject issues, in which case you will have to eject from the unit, or toggle the power switch on/off. This issue only arises if you have a particular chipset in your player (about a 20% chance).....good luck my friend.
Posted on Aug 01, 2007
drlalitv
  • 488 Answers
SOURCE: Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Posted on Nov 02, 2008
  • 1348 Answers
SOURCE: Won`t play DVD `S
you need to set the area in the settings menu.get the manual for it and it explains how to do it.every unit has a different procedure
Posted on May 23, 2009
SOURCE: unknown disk -samsung HT-x30 DVD Player
FIxed this by downloading the firmware upgrade from samsung and applying it.
Posted on Jan 10, 2010
muntejaya
  • 10421 Answers
SOURCE: I have a Samsung HTX250
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_cv56
Posted on Feb 27, 2011
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Unlock code for LG one box one cinema
is 4 your home code region i know 0 is all in main settings sumware they shoudl show rgion free ok if ot dvd sdont surport it ok usally have to a buy a region free player to play all disk from all ove rthe world ok thx agian nick helpap
Feb 06, 2008 | Audio Players & Recorders
Bought a new dvd it will not play, its giving me a regions code error. what is the code, and how do i put it in the dvd player?
A regions code error means that the player is not compatible to play a DVD from a different region than what it was designed to play. For example, if you purchased your player in the U.S. or Canada then it is a region 1 player and therefore will play DVD's from region 1.
Here is a region map http://www.mvps.org/marksxp/WindowsXP/dvd/regions/regions.php
There are however, ways around this as some manufacturers of players have made a way to be able to allow the end user to unlock the software codecs that are for different regions. You will have to search for an online source that has a download or a procedure to follow to unlock your player.
Nov 01, 2010 | Emerson EWR20V4 DVD Recorder/VCR
I need to change the region from 1 to 4
You have to go to the device manager of the operating system. List the hardware. Right click on the actual dvd drive and select the area that you want to change the region to. It will display the region.
Aug 10, 2009 | HP Pavilion dv5-1160us Notebook
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
All rgion code for ps3 (india)
dvds from different countries donot work on a home bought ps3
Nov 23, 2008 | Sony Playstation 3 (PS3) Console
Blueray
You can always invest in the program called AnyDVD. It can be found at
http://www.slysoft.com/en/anydvdhd.html
This should solve your region issues with the BlueRay disks. Run this program, then insert your movie into the dvd player, and watch the movie play. Take care and enjoy!
Aug 02, 2008 | Acer Aspire 3680 Laptop
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
Invlaid region code
Sounds like you are trying to play a DVD of a different region to that of the player.
Worldwide region codes, sumarised:
1 - US / Canada
2 - Europe
3 - Asia
4 - Australia
5 - Africa
6 - China
You can change the region code of the DVDR520H to any region or use region 0, which makes the unit multi-region to play DVDs from any region.
  1. Go into the main menu
  2. Highlight the exit button
  3. Type 2960
    This should give you access to a hidden menu form where you can change the region code.
Feb 20, 2008 | Philips DVDR520H DVD Player/HDD
Samsung Remote Control Ah59-02131f Home Theater Dvd System Lcd Tv Ln32a330j1d Logo
15 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
