Question about Ferrari High Back Booster
Ferrari car seat cover - Ferrari High Back Booster
Were can I buy a ferrari kids seat be one? I can find one!!!
Hi, you can buy the Ferrari Be One child car seat here:
http://blog.store.ferrari.com/2012/07/13/ferrari-carbon-fibre-chess-set/
or here:
http://gubibaby.com/2009/10/09/ferrari/ferrari-be-one-infant-seat/
Feb 19, 2013 | Ferrari Kids car seat Be one
Tip
How to Change Thermostat in Ferrari Enzo car?
1) First buy a new thermostat for you car year and model.
2) Then as per the procedure. Remove the radiator cap. Be careful that there will be pressure in the radiator. So just let the pressure release first before removing the cap completely.
3) The thermostat is connected to the black hose coming from radiator.
4) On the top of the engine there will be thermostat cover. The cover is fitted by two bolts on each side.
5) Then remove the hose connected to radio with the help of a pier.
6) The other end of the hose is connected at thermostat cover. Carefully remove the other end of the hose. A bit of coolant will flow from the hose while removing the hose.
7) Remove the screws holding the thermostat cover. Lift the cover after the screws are takes out. Then take the thermostat seated under the cover.
8) Remove the old gasket out from the thermostat with the help of knife.
9) Before removing the old thermostat carefully notice the position of old thermostat. In the same way place the new thermostat with the spring assembly in the down side of the engine.
10) Refit all the parts removed while removing the old thermostat properly.
11)After every thing is fitted proper as it was before, then check the coolant level if its low get it refilled till the required level.
This will help. Thanks.
on Mar 19, 2010 | Ferrari Enzo Cars & Trucks
Looking for instruction manual for ferrari dreamway booster seat
Try calling Ferrari customer service to ask about the Dreamway booster seat at:781.619.6979
Feb 16, 2013 | Ferrari Dreamway Booster Seat
Removing ferrari car seat cover to wash
Do not remove it unless you have the skills to remove the dozens of clips that hold the cover to the seat frame. BAD IDEA.
Oct 31, 2012 | Cars & Trucks
I want to washhe padding of my beline ferrari seat and can't get them out,any help??
if its fabric i found that the powder laundry soap,bucket of water and a microfiber wash cloth ....put 1 scoop in about 3 gal water wet cloth squeeze out most water ..leave damp wash repeat......step back and be amazed!!
Aug 16, 2012 | Ferrari Beline Toddler Car Seat
How do I remove the back rest from the car seat as a car booster?
If your Ferrari seat is the same as ours, you'll see that the backrest is connected to the base with two plastic prongs that you can see from the bottom of the base. I separated ours by standing on the base and pulling the backrest towards me - it takes a bit of force so be careful...and after making sure all the harnesses are not attached to the bottom!
Apr 30, 2011 | Ferrari High Back Booster
I have a ferrari car seat and im trying to put the
my kids ferrari car sound not working now how can i fix this plz
Feb 16, 2010 | Ferrari High Back Booster
How do I remove the head rest from the ferrari high back booster?
I have the same problem. I want to remove the headrest so that i can wash the cover. my car seat looks like the one on this pagehttp://4.bp.blogspot.com/_MrQjKKC90Ik/TKXqOfzH-cI/AAAAAAAAEic/Oe3gQmMldtM/s1600/ferrari+2.jpg
I cant load this page http://www.coscojuvenile.com/instructions.asp
Feb 26, 2009 | Ferrari High Back Booster
Ferrari High Back Booster Logo
46 people viewed this question
Top Ferrari Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Ferrari Baby Gear Expert? Answer questions, earn points and help others
