Default username password thomson tg789 - Computers & Internet
5 Suggested Answers
Hypnotoad
  • 55 Answers
SOURCE: Router Login
Look for a small hole in the back with a tiny button in it. With the power connected, stick a paper-clip in this hole and hole the button down for 5-10 seconds. This should reset the router back to default factory settings.
Not all models have this, but most do. Generally the hole will be near the power plug.
Posted on Feb 13, 2008
peglegcards
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
SOURCE: default password not working
you have to reset the router by pushing in on the reset button with a pen. this resets the router security to just a user id, no password. ID should be admin.
Posted on Nov 11, 2008
jeevan.m
  • 392 Answers
SOURCE: default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Posted on Jun 22, 2009
I have a thomson twg850 router but it won't accept my password, what do i do
Hello you might have to reset it and set it up again.
TWG850-4U Default IP: 192.168.0.1
TWG850-4U Default Password: admin
TWG850-4U Default Username:blank
Here is a guide:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Good luck
Nov 19, 2012 | Computers & Internet
How do I find and access the address and password to my Speed Touch 534818 home hub?
I couldn't find the model number of the speedtouch router that you've mentioned but this site has a long list of IP addresses and default usernames/passwords for the Thomson speedtouch range. Open a web browser and type in the IP address in the address bar such as 192.168.1.254, if the router responds you will be asked for a username and password, systematically work through the list on the afore mentioned site until you gain access. However, these details are sometimes printed onto a label on the router itself so I'd look there first for these details and the correct model number of your router in order to save yourself some time.
Apr 12, 2011 | Thomson Computers & Internet
I have just purchased a Thomson tg585v8 and am unable to log into the Thomson Gateway. I have tried all the usual defaults like; admin, admin; Administrator, Cp********, Administrator, "blank"...
Hello, usually the default for this type of router is;
the default username is Administrator (case sensitive). the default password is blank.
Be sure to type the user name with an capital 'A'
:) Hope this helps!
Feb 28, 2011 | Computers & Internet
Hi guys, i just got a thomson twg870 and i'm trying to connect to 192.168.0.1 but i can't find the username and password. I tryed with admin and "password" but it's not working. Any ideas? Thanks
pankystu,
The default username and password for most routers is:
username- admin
password- admin
OR
username- administrator
password-
Hope this helps.
-S
Oct 19, 2010 | Computers & Internet
I need username And Password to Speedtouch modem
Usually the username and password for this are : admin for username and admin also for password. Sometimes the pasword is 1234. If someone change the password then you can hard reset the adsl modem by pressing and holding a small hole ( usually on the side, its in the manual ) using a pen or a pin. Then the username and password will be in its default. Just check the manual. Sometimes the username and password is also written in the box or underneath the adsl modem. If this does not work, you can try calling your ISP.
Oct 06, 2010 | Thomson SpeedTouch 330 ADSL Modem
Need username and pwd
To access the configuration: The default user is 'Administrator' and the password is blank.
Make sure you have your DSL username and password to log into you DSL service. If you don't have it your service provider can give it to you.
If that doesn't work find the reset button on the back. Do not use the front reset. Hold the reset buttion in until the power led flashes red. This should reset the unit back to factory. You will need probably need you DSL username and password to re-configure the router.
Mar 06, 2010 | Thomson RCA DCM245R Modem
Password & username requested for site 192.168.0.1 Thomson say!
From what i remember the username is Admin/admin Administrator/administrator, the password field leave blank or if it requires one it will password or Password.
Regards.
Aug 03, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
I have thomson..and it is asking me the password i dont re call it
by default the password is admin, in all lower case, and the username is blank.
Jun 28, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Can't get router username and password, can't reset router
Default IP of ST546 is 192.168.1.254
no username and password is admin
Default IP of DG834G is 192.168.0.1
username is admin and password is password
Apr 25, 2009 | NetGear DG834G Router
Computers & Internet Logo
2,997 people viewed this question
David Payne
David Payne
