Question about Dryers
Flavel calibra gas fire continuous beeping without ignition
SOURCE: kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: vauxhall calibra will not start ignition light
Please Email me at paul_bryant@hotmail.co.uk and I will tell you how to by-pass the imob'
Posted on Aug 29, 2009
  • 277 Answers
Go to GM Vauxhall website and it will indicate where to archive User Handbooks, or invest in a Haynes Manual, which as a new owner of a late model, I would suggest, be a better and safer bet. You then have 99% of Repair and Fault Finding information. Cheaper than a Garage if you have DIY expertise.
In the UK, about 25 GBP.
Regards,DT
Nevada, USA
Testimonial: "thank you but i have since found it is an add on make unknown"
  • 14 Answers
best thig to do is run a live and earth lead from your batery straight to your starter motor (by passing the imobilise) to see if it starts if so you got your self a immobiliser fault (witch i reckon it sounds like ) need anymore info let me know.
Posted on Jan 15, 2010
heatman101
  • 43501 Answers
SOURCE: igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 19, 2010
Whrre is the battery compartment for flavel cascade 50 cooker please
Flavel : Manuals
www.flavelappliances.com/Products/Manuals
If you've lost or misplaced an instruction manual to one of your Flavel products, don't ... Electric Fan Oven with Separate Grill ... 60cm Side Control Gas Hob.
Sep 09, 2015 | Ovens
Flavel emberglow takes ages to ignite then you have to hold control in for a while or it goes out
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Nov 09, 2014 | Dryers
Starter just spins after ignition wire replaces - no fire
Sounds like you have the starter wires hooked up wrong and to continuous power. If starter shuts off with the key now, but wont engage the motor, you may need shims so that the starter drive lines up with the motors fly wheel
Apr 09, 2014 | 1995 Chrysler LHS
Flavel emberglow classic gas fire
No it should not. Soot usually indicates incomplete combustion and the air shutter may need to be adjusted. Intake and exhaust piping should also be checked for any obstructions.
Dec 22, 2013 | Heating & Cooling
Helllo there my name is mr ralph broom. i purchased a gas fire from sales@fires-cookers.co.uk, it was delivered on 21-09-1010, the fire had a part missing the glass front panel i contacted the company....
flavel is made by lesure i would google both to confirm who makes this fire , or ask for you money back in full or go to trading standards , no fire which is new will have parts missing , i will look on the net and be back to you later
Nov 06, 2010 | Heating & Cooling
The problem with the 1993 calibra is it is firing on cyl. 2 & 3 not on 1 & 4
The problem is the ignition coil. It fires the cilinders in pairs. Change it and problably the problem will disapear...
Dec 08, 2009 | 1996 Volkswagen Cabrio
Vauxhall calibra will not start ignition light
Aug 29, 2009 | 1996 Volkswagen Cabrio
Regards,DT
Nevada, USA
Aug 29, 2009 | 1993 Volkswagen Cabriolet
Dryers Logo
154 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
