Question about BMW Vehicle Parts & Accessories
Binding front brakes
Front brakes binding when car run for about 5 miles
  • BMW Master
  • 14,417 Answers
Calibers needing replacing,always replace both.
Posted on Nov 06, 2012
Isuzu trooper wheel discs overheating
Have you recently changed rotors?
Jun 02, 2014 | 2002 Isuzu Trooper
Replaced front axle bearing on 96 ford taurus two times it keeps coming a part after driving 1 mile
Make sure the brake caliper is not binding causing abnormal load on the bearing.
Nov 14, 2009 | 1996 Ford Taurus
I have a 2005 chevy equinox i replace the front rotors and brakes now when you come to a stop the car sounds like the abs system is kicking in
check the connections on the abs, behind the rotor by strut is the connection for the abs if the connector is loose or not properly affixed to the clip it sets off the abs trouble code or low speed saftey usually activates at slow speed under 5 miles an hour the connector and clip are part of the abs circuit--also recheck ur brake pads for binding and brake fluid level --if u get a trouble code have vehicle scanned some auo stores such as auto zone / advanced auto scan for free this will tell u which sensor or unit is causing problem
Oct 24, 2009 | 2005 Chevrolet Equinox
Have a 1979 Suzuki 850 Motorcycle. Front brakes binding.
the problem is in master cylinder-needs to be replaced or inspected-purchase a clymer manual--u can ride without a front brake by law-wen I built choppers we never had a front one
Sep 08, 2009 | 1979 Suzuki GS 750 E
BRAKE DRAG & NOISE
check your calipers to make sure the pistons inside are moving and extracting evently
Nov 25, 2008 | 2000 Daewoo Leganza
FRONT LEFT SIDE BRAKE NOISE & BINDING
It may be caused by Disc Thickness Variation, which occurs when the pads brush the sides of an out of alignment rotor. Also, it could be that the rotors need to be resurfaced due to poor surface finish. I have also seen that when the brakes drag on the pads (DTV) that any pad dust will collect in the low spots and squeal after braking. I would recommend dropping the calipers and thoroughly cleaning the rotors and pads off with warm soapy water and a rag. I don't recommend brake cleaner or silencing sprays because they just add un-needed material to a contact surface and can actually cause noise and prevent full pad contact.
See HERE for troubleshooting information from English Brake Corp.
See HERE for Tech Questions answered from Bendix Corp.
I can also suggest checking the hub face with a roller-tipped dial indicator gauge to confirm that it doesn't have any lateral run-out. Run-out of over .002" would be out of spec.
HOPE THIS HELPS!!! Please don't forget to rate!
Thanks -
Peugeot 806 s reg front brakes binding
Flush the brake fluid at the calipers for the whole system. Keep adding new fluid into the master to be sure to flush it all and check to make sure you're using the same DOT spec (3 or 4). Water expands when it gets hot, possibly keeping positive brake pressure at non-braking. Brake fluid absorbs water and the only place to get water is at the seals in the calipers.
Bad flex hoses would be an all-the-time problem, not just at higher temperatures.
Jun 21, 2008 | Peugeot Liberte Cars & Trucks
Front brakes binding and grinding
Sounds like your brake calibers are sticking. Get new ones and new pads. You probably should get new rotors also because with the dragging calibers they most likely got hot and are warped. Search on ebay and www.rockauto.com . I personally use power stop drilled and slotted rotors with mid grade pads. You can probably get a whole kit.
Oct 22, 2017 | 2000 Ford Windstar
Vehicle Parts & Accessories Logo
46 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
