Question about Electronics - Others
Panasonic DMR-EX99VEBK Recorder Duplicates and deletes programmes entered from the Guide
Add programmes from the Guide to be recorded to Hdd, Dvd or VHS. The recorder duplicates a program 6 times and deletes others yet to be recorded
Palmbeach
  • 185 Answers
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
Posted on Feb 24, 2008
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
buffalonyman
  • 1865 Answers
SOURCE: LG DVD recorder will not recognise any blank dvd's
The lasers do burn out, if nothing is reading, then perhaps the laser did burn out
Posted on Nov 02, 2009
Grubhead
  • 5391 Answers
SOURCE: Region 0 DVD's will not play
I understand that what you call 'region free' is Zero! Therefore this discs you are trying are not zero. Try inputing different numbers to get them to play.
Region Free is a myth!
Posted on Dec 14, 2009
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
We have a Panasonic DMR-EH55 dvd recorder, it worked just fine until March, 2009 when Shaw quit subscribing to tv guide. Has there been any resolution to this issue?
Shaw like Time Warner in many areas of the U.S. will never go back to TV guide.
Your best bet is to switch to the competition in your area.
Jan 31, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
I have an HDD rerecorder that now sjips and freezes
HD takes more info and if you don't have a fast enough processor to handle this, that might be the problem.
The age of the recorder would tell you that. If it's 3 years old that might be it. Also how can the recorder record the HD signal unless it has the right tuner??
Dec 29, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How do I copy a programme I have recorded on the HDD to a DVD-R. I have a 1 hour TV programme recorded on my Panasonic DMR-EH50 hard drive that I want to copy to a DVD-R. Can you help me do this please.
On your machine or on the r/control you should have a copy button,if you press this you should get a menu come up on screen.It should ask you which way you want to copy,so you will go HDD-DVD-R,then press copy again and it should do it automatic,hope this helps.
Jul 11, 2009 | Panasonic DMR-EH50 DVD Recorder
DMR-EH55 HDD ERROR
Can you be a bit more specific? You cannot read the TV guide, instructions and other data or only the list of programs you ahve recorded?
Jun 07, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Electronics - Others Logo
41 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
