Updated to latest firmware, 1.00.16 (Jul 2 2010 14:36:56), and now internet speed is about 33% compared to straight from the modem.
SOURCE: Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
SOURCE: is it possible to update
Hi Friend,
Please refer to the link
http://homesupport.cisco.com/en-us/wireless/lbc/WCG200
You cannot upgrade the firmware, instead you can download the vista drivers for your cable gateway modem.
Regards
Chiranjeet
SOURCE: Im using DIR600 and is
The following is my solution for similar problem with D-Link DIR300. I hope it would be helpful to you as well.
Reset the router to factory default setting, press and hold the
reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored.
Please note that, after resetting the router you should be able to see
the router and connect to it via LAN Cable of Wirelessly as the router
automatic assigns the IP Address and gateway etc. Before proceeding to
the next step please make sure that you are getting the signals as well
as internet. However, the internet connection would not be secure, which
can be done later.
Now, all
you have to do is connect to the router and secure
the connection follow the following steps: -
First
you have to access the router through web browser (Internet Explorer)
by typing the IP address of your router in the address bar, which is
192.168.0.1 (Default router settings are written under the router) (unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the
following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup"
2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
In the screen shot below I have highlighted the above mentioned options.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback and approciate the efforts.
CreativeTECH
SOURCE: Firmware upgrade for Speedstream SS2602
The information may be a bit misleading. What COX said about DOCSIS version is for cable modem standard. The higher the number the better the speed. However, it seems that the modem is already getting THAT speed. Some other device (perhap SS2602) is slowing it down.
It seems that SS2602's WAN side only support 10Mbps connection, which, in term, limit the speed to 10Mbps each way. The actual throughput may be even lower. Should that be the case a new router would be recommanded.
PS3, Xbox, Wii, Setup
http://fixhomenetwork.com/xbox-play-station-wii.php
