Question about Hitachi 1TB External USB 2.0 Hard Drive
External hard disk not detected and can hear beep sound 1tb 2.0usb xl1000
  • Hitachi Master
  • 27,725 Answers
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 31, 2012
lock123
  • 6831 Answers
SOURCE: Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Posted on Sep 25, 2009
JulesPCaut
  • 702 Answers
SOURCE: I can't see the hd symbol
Check the Disk Management console to see if the hard disk is partitioned and formatted.
Right-click My Computer and select Manage in the popup menu.
Posted on Dec 19, 2009
Geekman
  • 32281 Answers
SOURCE: hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on May 15, 2010
Testimonial: "is there any to tto got it corrected?"
  • 79 Answers
SOURCE: TI dont see the external hard driver hitatchi
Have you made sure that the cable has good connections at both ends? Have you tried another cable or try the drive on another computer? If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Posted on Feb 07, 2011
  • 823 Answers
SOURCE: my hitachi 1tb xl1000 drive
It means that there is no operating system installed on your hard drive and so it will not work until you add one. Buy a windows xp disk or an operating system that you wish to use and put the disk in the cd/dvd rom. Reboot the pc to get it to pick up on the disk in the drive and then follow the prompts to install an operating system.
Posted on Mar 21, 2011
1tb is beeping
I'm sorry to tell you this but unfortunately the fall killed it.
Jun 27, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
External Hard disk is not detecting on my desktop PC
Try a different usb port. Maybe a 1TB external hd is too big for your old computer to recognize. Old computers cannot handle a drive that large.
Jun 08, 2012 | Computers & Internet
Hi I have a HITACHI XL1000 1TB External Hard Drive, and every time i connect it to my PC or laptop it says the drive needs to be formatted but then a message appears saying windows is unable to format it....
It sounds like the disk might be bad and need to replace it But go to the link I have provided and download the drive fitness tool and let it check your drive you might be able to do a low level Format\
http://www.hitachigst.com/support/downloads/#DFT
Aug 30, 2011 | Hitachi 0s02484 XSeries Desktop 1tb...
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Jun 09, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
My hitachi 1tb xl1000 drive wont read my files and is saying that the drive is not formatted. What is this?
Mar 21, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My hitachi xl1000 fell over and now it's making a clicking sound and not being recognized by my Imac
Unfortunately, if the drive falls it can damage a drive, if it is running it can be very bad. The clicking sound you hear is the drive heads clicking against the platter. Your drive will need to be replaced.
Feb 21, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
When i connect hitachi xl1000 the disk is recognized but when i want to access i get message that disk isnot formatted
Did anyone respond to you with a solution? I'm having the same problem with mine. If you did have your problem solved can you share with me?
Feb 14, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I can not format my Hitachi XL1000 for mac
Use Partition Magic to convert your partition.
Think this is helpful !
Aug 11, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi 1TB External USB 2.0 Hard Drive Logo
211 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
