Blank monitor in my dell laptop - Computers & Internet
  • 7,627 Answers
Is the laptop running, if so can you see the very faint OS in a bright light? if so I may can help you
Posted on Oct 31, 2012
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Want to turn off laptop monitor and use an external lcd monitor
Usually when you plug in that monito the laptop should go blank. If not find setting in BIOS to turn laptop monitor off.
Dec 04, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
The screen is not coming on at all. i connected
With the external monitor connected, try holding down the FN key and pressing one of the F keys at the top of the keyboard that has a Monitor icon on it. This should turn off the external screen and show the laptop screen. If you press it a 2nd time, BOTH screens should show up. If still blank, Press again until the External Monitor comes back on. Then go to www.dell.com/support and go to Drivers for your Model. Then download and re install the VIDEO or DISPLAY Drivers. This should fix it if its a missing driver. If STILL no display on the laptop, call Dell.
Oct 21, 2009 | Dell Inspiron 9300 Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
External montior is blank
Are you sure the laptop is powering up?
Do you hear the laptop boot up and the hard drive spinning and the power LED is on when you connected the external monitor?
The monitor must be powered up before the laptop for the video info to switch video port automatically.
If the external monitor is blank then you can't make it work, your video card is faulty and it is not possible to replace as it is built-in on the motherboard. You could replace the motherboard but this may not be a cost effective solution,
May 05, 2009 | Dell Latitude D610 Laptop Computer -...
Blank monitor
Try the following link for all Dell monitor problems:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&docid=FC55E86F0611BEE3E030030ABD620A8C&l=en&s=gen
Good luck and hope this helps.
Feb 23, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Computers & Internet Logo
David Payne
David Payne
