Question about Amana Washing Machines
Alternative sealant for tub gasket on Amana FWA05AW topload washer
Must I wait a week for a tube of 3M Scotch Seal 800 Industrial Sealant to arrive by special order? None locally available that I can find. Anyone have an alternate sealant for installing the transmission shaft tub seal gasket on an enameled steel washer tub? Any reason I shouldn't use RTV? Is it because 3M 800 is a polyurethane, MEK based sealant that's soap-resistant? Anecdotal and scientific answers appreciated...
  • 833 Answers
SOURCE: Have a tub main bearing needing replaced on Amana LWA40AW2
Generally, if you need sealant, you can use any kind of automotive sealant. The best ones are the rubber-based gasket sealants. Be sure the surfaces are clean before applying and use only enough to make a thin bead. About the bearing: If you have no access to a press, you can often use a piece of pipe (either plastic or steel) which is just large enough to slip over the shaft and pound the bearing into place with a mallet. The pipe should contact only the inner (shaft contacting) race. Be sure it is square. You should lightly lubricate the area where the bearing will seat and also the inside lip and bore of the seal. .
Posted on Jan 14, 2008
the dr
  • 447 Answers
SOURCE: Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Posted on Jan 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: #285352 Trust Plug (Input Shaft) Seal R&R
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
- With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Worn out drum bearing and seal
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DISASSEMBLY:
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
REASSEMBLY:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
Posted on Sep 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore Oasis washer--model#11027082604 is leaking
As far as I can remember there is supposed to be a lip seal for this motor. I must apologize because I am not sure this is 100 % correct... but this number 425009P is on one of my old invoices. I am NOT sure that seal is for an Oasis. I am sure it is for a smart drive machine.
I did a net search for that number and it only shows up on the Fisher and Paykel machines that are similar to the Oasis. See for your self and feel free ask / seek another expert.
Kelly
Posted on Jun 02, 2011
Water leaks out the bottom through through the clutch when filled and running
There are gaskets and shaft seals that can leak. Not an easy task. On my GE washer, I had pinhole leaks near the transmission mounting flange. I used JB Weld epoxy and sheet metal screws to seal the leaks. and of course changed the gasket. That was 8-9years ago. So my investment in time and transmission paid off. A bright light under the clutch and a dark room may show what's leaking. you may be able to temporarily seal with a window caulk from the top or bottom Or a bathtub waterproof sealant. If it's the rubber gasket, a rubberized sealant "may" help. I guess it could also be the pump. I use paper towels tied around things like drain pipes to find leaks, or make sure my work is not leaking.
Mar 12, 2015 | Maytag Centennial MVWC6ESWW 4.0 cu. ft....
I have a 2001 kia sportage. There is oil leaking into where the spark plugs are and shorting them out. Where could the leak be coming from?
You have a broken seal that is seated around the tube where SPARK PLUGS go thru. Fixing it is easy for a novice mechanic, just remove the VALVE COVER and u will see the SEAL around the tube, clean the area around the tube so that it will be oil free, replace all 4 seals, and put in a new one w/ a light coat of silicone sealant,clean also the valve cover gasket put some sealant. Put back the cover and ur done! Hope that makes ur day! taaah!
Nov 11, 2010 | 2001 Kia Sportage
With a cracked tub o a washe tuber, is replacing the tub the only solution, or is there some type of sealant or adhesive that could be used?
You may use a two-part epoxy adhesive/sealant but the cause of the crack must be addressed first. The tub will eventually be damaged completely if there's an issue with the inner basket banging the sides of the the tub. Address any balance issues then take the tub out to apply the sealant properly.
Jul 09, 2010 | Maytag PAV2300 Top Load Washer
I have kenmore 970c4006200 plastic tub water leak
Perhaps been hit by a coin..Try sealing with silicone, give it a good clean 1st the roughen it with sandpaper to give it a Key......It may of course be from the Door boot seal you need to check this and @ pump also just in case..Please leave feedback
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
On the rear of my dryers there is a round gasket that is falling off, how do i replace it?
At the rear of the dryer ? You don't mean the drum do you ? It's a felt drum seal. All that's required is a new seal and some hi temp sealant (3M-1800 If I recall...it's been a while since I've had to purchase it by name) to apply it to the drum. Good luck, hope that seals the deal !
Sep 26, 2009 | Kenmore Dryers
USED MOPAR ENGINE SEALANT, BUT VALVE COVER IS STILL LEAKING
You did everything correctly "by the book", but I add one thing...Once the orininal application has set up, I add another thin layer, then immediately set the cover in place on the engine can't slide it around or wipe it across anything when doing this though or it won't work. I then tighten the cover lightly, wait a couple of hours then re-tighten.Follow a pattern like torquing a cylionder head so it goes down evenly.
On yours, did you try just tightening up on it a bit?
Apr 27, 2009 | 1989 Jeep Cherokee
Jeep Wrangler 4.0 oil pan leak
Put it on the Gasket and Install wet. Just make sure that everything that it is going to Seal to is Clean and Grease and Dirt Free for a Good Seal.
Jan 26, 2009 | 1997 Jeep Wrangler
Outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Jan 14, 2008 | LG WM2077CW Laundry XL Front Load...
Washing machine problem...
A good marine type silicone sealant (like what you might use on boats) might buy you some time. However, with the vibration of the machine and the torque applied to the tub when the transmission and drive motor engage to spin will only make the crack worse over time. Sorry, but you might want to think about replacing the tub.
Aug 11, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
175 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
