Question about AEG Dishwashers
How to locate thermostat in AEG 40630 dishwasher
Water is cold. I took out the heating element and it works good when supplied direct 220V. Can someone describe how to find the thermostat? Thank you!
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
  • 132 Answers
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Posted on Jun 14, 2009
joe_lishman
  • 192 Answers
SOURCE: Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Posted on Jan 17, 2010
  • 523 Answers
SOURCE: Do all dishwashers use heat element or do any
all dishwashers use heaters and all should be connected to hot water the heater is only to keep the water hot not to heat it
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: AEG Favorit Integrated Dishwasher failing
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 23, 2011
Favorit 84470VI
Heater, 230V./2000W.-d.32mm.
The heating element, which is encased inside a tube, is used to heat the washing water. The heating element is not activated during the drying phase. Inserted into the delivery side of the washing pump and coupled with the duct which directs water to the upper spray arm.
Built-in safety devices: Two thermostats
First thermostat: auto-reset bi-metal thermostat calibrated to 98°C and connected in series to one branch of the heating element.
Second thermostat: manual-reset fuse calibrated to 206°C and connected in series to the second branch of the heating element. If this fuse intervenes, the heating element is disconnected definitively.
25966855-vhkvuwxe0dpywjiqbdtoypy4-4-0.jpg Dado
Nov 18, 2015 | AEG Dishwashers
Water won't heat
It could be a malfunction heating element, thermostat or both.
In most cases it's the heating element.
Check with a multi-meter for 115/220V on the heater tags.
In case you get this voltage there, you should replace the heating element.
In case you can't read the 115/220V on the heater tags, check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat.
Good luck
Source:http://www.fixya.com/support/t188408-dishwasher_not_heating
Apr 18, 2012 | Dishwashers
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Oct 24, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
Dishwasher not heating
It could be a malfunction heating element, thermostat or both. In most cases it's the heating element. Check with a multi-meter for 115/220V on the heater tags. In case you get this voltage there, you should replace the heating element. In case you can't read the 115/220V on the heater tags, check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat. Good luck
Aug 27, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
55 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
