Question about Refrigerators
Kenmore Inverter Control Boxes
Plastice looks like a blade
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
Why does my Kenmore model 721.63352300 count down but wont turn on?
There are two relays on the main control board. They look like white boxes. One of them is probably bad. Those relays turn on the rest of the unit. http://www.discountrepairparts.com/product-p/drp14113.htm
Jan 27, 2017 | Kenmore Dryers
How do I cut a plastic packaging tube to be shorter?
No, I'm not going to run over to Ross to check one of the tubes! If the material is very thin, I use a single-edge razor blade but thicker material requires a utility knife or some other sharp bladed tool.
Dec 01, 2016 | Miscellaneous
Can you buy tool boxes that are made from plastic?
Yes, there are some amazing and sturdy tool boxes out there that are made from plastic. They are very durable but not as heavy as the metal ones.
Take a look at the Keter website. They specialize in household plastic goods;
http://www.keter.com/categories/tool-storage/tool-boxes
Jan 31, 2013 | Hardware & Accessories
This kenmore 1102670090 cloth washer will not drain... can
You will most likely need a water pump. Take the screwa out of the control panel. There is one on each end under the plastic covers. Pull the console as you lift. It will fold out of the way over the back. Unplug the wires in the middle under the console and then un-clip the clips on each back corner also under console. I use a flat blade screw driver. Now tils the case foward and lift off. Once you have removed the case. You will see the water pump at the bottom. It has two hoses connected to it. You will need to remove the water from the machine with something like a small pump that runs off of a drill. Remove the two clips and hoses. Put new pump on and put machine back togther. It;s not as hard as it sounds once you get started. It real easy.
Oct 16, 2009 | Kenmore 22422 Top Load Washer
Dell monitor will come on but will not stay on. stays on 5sec
5 seconds? Hmm, too long for inverter driver turning into protection caused by bad lamps. Also too long for PWM controller in the switching power supply.
Rather looks like overheating of the FETs in the inverter, they are driving HV-transformers. Open the monitor, remove metal lid and observe inverter board. If PCB under and around these FETs is darkened, replace them.
These Dells hard to open. Take the foot off and unscrew plastic cover. Then using flat screwdriver with wide blade separate plastic halves of the case, starting from bottom edge and moving to opposite. It might be sweaty.
Sep 13, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
I have Kenmore Elite washer (110.24942301) with bad timer, but I can't get to the timer to change it. No screws visible and no plastic caps on sides. There are plastic hinges screwed on behind the top...
Here is a link to a diagram of your control head on your washer. Make the diagram full size and zoom in, (the options to do that will be in blue on the border at the top of the diagram). Use a flat blade screw driver to push from the front on the clip, (#8 in the diagram), and the head should release and lift up. Good luck and don't forget to write back if you need further assistance and/or If I have helped you fix it! Good Luck! Click on the link below.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11024942301&productCategoryId=0153200&brandId=0582&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=CONTROL
May 13, 2009 | Kenmore 24032\24036 Top Load Washer
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Kenmore elite washer
nope, the knob does not come off in order to remove the panel off.
look at the edges of the back of the control panel, you should find philips screws at the back. if not then figure out how to remove the plastic edges of the panel. they are covering the screws.
if you found the screws, remove them then pull the panel towards you and the plastics hooks at the bottom of the panel would slide out towards you.
then you were able to open the control panel..
hope it works..
tnx 4 using fixya,
drcool
Sep 10, 2008 | Kenmore 23822 Top Load Washer
Kenmore side by side (2003)
Dont mean to butt in here but your refrig probably has a ECM (electronic contolled motor) which means it has a tiny computer inside it....these motors are plastic and have a plastic blade. these are a little more energy efficient and it helps the manuf get bettter energy star ratings...however...they do from time to time decide not to start every time that the unit comes on...this cause excessive heat and freon pressure to be exerted on the compressor and its electricals... The replacement motor is just the old style shade pole (magnets) motor...not quite as quiet or efficient but wayyyy more reliable. Order a replacement blade seperately from the blade/motor kit since the blade in the kit is always destroyed by the motor inside the box.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
