How to configure my laptop so window fits monitor display
The display on screen of monitor needs to be reduced in size slightly.How do I configure my laptop so that the monitor display fits the window correctly
    Sergeant:
  • 265 Answers
Hi ,
You can right click on your laptop , and this will bring up a menu , look for screen\ res. , highlight and click , this will take you to the display prop. ,on the left hand side you see change display res. when this menu pops up , you will have a chance to change the res. I would go with 1024x 768 res. it seems to be the best res. to fill the display .
Goodluck Roy
Posted on Oct 31, 2012
sandrew
  • 2961 Answers
SOURCE: IBM T20 2647 loaded with Microsoft XP pro
you should be able to right click on your desktop and select properties and on the settings tab select the screen resolution to atleast 800 x 600, if you cannot and only 640 x 480 is available, the the driver may be corrupt for you graphics card. Go to the link below and download the driver for your graphics from here and install:- http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4JRNJB Go to my computer>properties>hardware tab>device manager and look in the list at graphics adapters, right click on it and select update driver and the downloaded driver should be found, you may see an exclamation mark at the graphics line, this wiil mean there is no driver for the card and by right clicking again on it and select update driver should sort it, reboot pc and see if you can alter the screen resolution.
Posted on Jun 17, 2007
SOURCE: Laptop LCD problem
maybe the problems is your resolusion is to high
so you need to resize your resolusion.,
1.turn on your laptop
quickly hit F8 ( do not leave hit F8 until you see a safe mode, but don,t choose dsafe mode.,but choose enable vga mode).
3.if your laptop does,t appears safe mode or enable vga mode
you can repeat step one..
other solusion you can do step 1 and then wait until appears option safe mode ( but do not leave your finger hit F8 until appears menu safe mode.,and you choose safe mode and klik ok and yes and right klik on the desktop and choose propertis and setting and you see screen resolution and move the screen resolution until 800 x 600 and ok and restart and every thing will be normal..
from tandra halim.,solution for 1
Posted on Mar 20, 2008
ahmed_9004
  • 17 Answers
SOURCE: Graphics Display
that is so easy, all you have to do is install the graphic card driver from the TOSHIBA Driver disk and then reboot your PC , and everything will be fine
Posted on Jun 01, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Display is wrong - only 3 resolutions available
install the display drivers, then check
Posted on Oct 28, 2008
SOURCE: Display problem
may be ur display & graphics driver not installed properly , first u uninstall the driver from ur system and restart the system after restarting the system reinstall these drivers properly after one driver installing if it ask for restart then restart the system , after restarting the system check. I think ur problem will solved
Posted on Jun 02, 2009
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
Tip
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
on Aug 23, 2010 | Televison & Video
What is the recommended resolution for HP2009M
The stated native resolution of this monitor is 1600 x 900. If you set your display resolution to that in your computer's configuration, you will get the sharpest display.
Note that there is always a trade-off between sharp image and the size of displayed items on the screen. By that I mean that if you set your display to 1600x900, your text will be sharp, but it will be smaller on the screen than if you see the resolution to 1280x720, for example. The trade-off would be larger text (say, if you have vision problems), but the text would not be as crisp.
Experiment with a few different resolutions to see what looks the best and has the best text size on your screen.
Note also that most browsers will let you enlarge the web page on your display by pressing Ctrl+ repeatedly until you get the size you want. Pressing Ctrl- will reduce the web page displayed size.
Oct 16, 2014 | HP 2009M Monitor
Make computer display fit tv screen mitsubishi wd 65738
If you are only going to use the set with the laptop here is a link to the service manual with electrical adjustments for height, width and other things---"enter at your own risk.'
http://www.scribd.com/doc/52160908/27/Service-Menu
Dec 15, 2012 | Mitsubishi WD-65738 DLP TV
Can i adjust size of display as a cracked screen has blocked some
Hi. The best thing to do is to get an external monitor and connect it to your laptop. Press Fn+F8 to show the display on your ext monitor.
^_^
Jun 07, 2010 | Dell Latitude D600 Notebook
Using as a duo monitor. when transfering screen image to it, the screen is extremely too large . How do I reduce the size?
Increase the resolution of the monitor with the really large image. Also, in vista and windows 7, go to display and there should be a button to reduce the size of whats on the screen.
Feb 02, 2010 | Samsung Computers & Internet
Laptop screne displaying 1/2 orginal size. need to reset pls
Jak, Go to Start->Control Panel->System->Hardware->Device Manager-> Display/Monitor. Select the monitor and uninstall it. The Go to Actions and select Scan foe new Hardware. Windows will automatically detect the hardware and install the driver for it. Save it and reboot into full screen windows.
Oct 26, 2009 | Computers & Internet
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
How can I reduce the text shown on a 15'' ibm g78 monitor
well you can try
control panel
accessibilty option
pick a task
configure window to work for you
next
pick one of those
Feb 17, 2009 | IBM G78 (Refurbished) (Black) 17 in.CRT...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
