Question about Car Audio & Video
How do i hook up my amp with no hi input and the radio dont have rca jacks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
At any decent car audio store, you should be able to get a high level to low level converter.
Posted on Oct 31, 2012
HLuis
  • 19 Answers
SOURCE: RCA INPUT JACKS
did it work well before?is it new? try moving the rca's and se if you hear any thing?
Posted on Jul 03, 2007
  • 631 Answers
SOURCE: can't get my amp to turn on
You need to confirm that you have sufficient B+ and remote turn-on voltage.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 07, 2008
tech48
  • 624 Answers
SOURCE: trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Posted on Jun 22, 2008
  • 11 Answers
SOURCE: Broken RCA / phono jack - where to find new part?
You can buy Panel mount RCA (Phono) jacks at Radioshack, I think a 4 pack is less than 5 bucks, That should take care of your problem.
Good Luck,
Stay Classy
B.
Posted on Apr 01, 2009
etirbynnor
  • 655 Answers
SOURCE: PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
Posted on May 24, 2009
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
Apr 29, 2012 | Cars & Trucks
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
The Pioneer GM-5100T wiring help?!!
i just sent you the manual for your am everything you need to know is in there. i also have tht plug if you need it. but will only be used for high level inputs for factory radio's if you have a after market radio use your rca jacks. or if you want you could use a converter if you have a factory radio that makes speakers outputs from the radiointo rca jack that will go into the amp. the rca'sare the best way it will sound much cleaner. good luck
Sep 27, 2009 | Car Audio & Video
My kac 7202 amp turns on but nothing comes out with everything hooked up
Use process of elimination. Connect the speakers that are hooked up to your amp directly to the radio, if they work check your amp. Make sure the rca jacks are connected properly. Sometimes the radio has rca's that are "inputs", make sure they're connected to the "output" rca's. If those are ok, your amp may be faulty. Try the amp on your friend's car see if it works. If it doues your radio might be at fault...or just bad rca cables. like i said, use process of elimination to narrow down the faulty equipment.
Sep 14, 2009 | Car Audio & Video
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Aux input on Soundstorm amp
If the amplifiers have RCA jacks, you can use an adapter cable to go from the headphone jack to the RCA inputs on the amp. If you're in the U.S., Radio Shack will likely have what you need.
Jun 30, 2008 | Soundstorm 2F400 Car Audio Amplifier
Trying to hook up amplifier to after market 6by 9 using factory radio
Jun 20, 2008 | Car Audio & Video
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Wireing
I believe that this model Sony amp includes High Level inputs. Those allow you to connect the normal speaker wires coming out of the factory stereo to the amp. If for some reason it doesn't include the inputs you can buy a high level to low lever converter that will give you rca from the factory unit.
May 06, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
