Question about HP Office Equipment & Supplies
Text not aligned
3 days ago my printer suddenly began printing all documents skewed. Printing quality is fine, only that all prints are skewed/not aligned. Since I had "refill" cartridges and was getting a message from HP Solutions Centre showing an error with at least one cartridge, I assumed the problem was with the cartridges. As you will see below though, I now think think that the problem was not with cartridges but rather with having put printer in draft mode. Yesterday, still thinking the problem was with the cartridges, I replaced the cartridges with genuine HP cartridges. The printing was still skewed/not aligned. - I have tried repeatedly to manually realign via the HP Solutions Centre toolbox function. It does not help. The alignment page itself, which otherwise prints out perfectly, comes out skewed/not aligned! - I have tried cleaning the heads via the HP Solutions Centre followed by going through the alignment procedure once more and still nothing changes. Oddly, this morning, I printed a one-page letter in normal mode expecting it to be skewed, but it came out - to my great surprise - perfectly! I then set the printer in draft mode to print a copy of the same letter and that copy draft-mode copy came out skewed. I have reset the printer to normal, but now as before everything is coming out skewed again. As a result of what has just happened, and now what I have been reading in forums, it seems that this machine has a habit of reacting badly after being placed in draft mode. - Ive just tried the realignment process again and, as before, it does not help. - I unplugged the printer while it was on and pulled the power cord from the printer itself in an attempt to get it to reset itself. This has made no difference. What I dont understand is that this crazy printer did suddenly give me one page perfectly. Only after I went into draft mode did it start to print skewed again. I now believe that (putting the printer in draft mode and not the cartridges) is what caused the problem to start 3 days ago. What can I do to get this machine to start printing properly again - as it did all of a sudden and all on its own this morning? Thank you!
  • Mark Nov 01, 2012
    The printer model is HP F4280
  • 5 Answers
SOURCE: Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Posted on Oct 14, 2008
  • 990 Answers
SOURCE: Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Posted on Dec 13, 2008
SOURCE: HP psc 2110 Printer keeps
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
Posted on Jan 28, 2009
Ajkill
  • 2035 Answers
SOURCE: error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 03, 2009
  • 14 Answers
SOURCE: Epson Artison 800 Poor Print Quality
it sounds like you have clogged the head if you leave it for 6 hours then the ink will dry inside the head then you have a big prob if i were you i would take it back to the shop and get a refund or a replacement one i have an epson dx4400 very good
Posted on Mar 21, 2009
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
May 09, 2017 | Canon PIXMA MX870 Wireless Office...
Is there a way to change the print quality from "normal" to "high"?
usually, if not all almost all printers allow you to set printing preferences before you print.
1. In windows, when you are about to print a document or photo, click preferences then you should be able to change printing quality. Usually, printers have radio buttons(option
buttons to select best "text","best quality", "photo quality" and "best photo quality". Just selct your preferences then click ok, then print.
2. If printing photos, there will be a warning to use photo paper instead of the usual paper.
3. Did this answer your question?
Jul 01, 2011 | Office Equipment & Supplies
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Print quality suddenly degraded
Sounds like your print head went bad. You will have to buy another one.
Jun 04, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
