Question about Sony Audio Players & Recorders
Sony muteki 7.2 sub amp doesnt work
Everything is plugged in properly never had a problem yesterday the subs just cut out i re wired it multiple time still doesnt work did my amp blow up or something?
SOURCE: fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
Posted on May 31, 2009
robotek
  • 1512 Answers
SOURCE: Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Posted on Feb 14, 2008
SOURCE: Sony Active Subwoofer noise
need a schematic for a sony sawmsp1 active subwoofer....anyone????
Posted on Jul 17, 2009
SOURCE: Sunfire Subwoofer 110 Noise on input plugin
This problem can also be caused by bad caps. This seems to be a real problem with this unit but considering the age I would replace the caps.
Posted on Dec 16, 2009
Jexx
  • 148 Answers
SOURCE: p3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I own two of these subs. i have a dual 10 inch box. but i keep blowing one of the subs in the same spot in the enclosure. Or in other words, the sub on one side of the box doesnt blow but the sub on the...
It may not be the box it could be that channel on the amp or the wiring of that channel double check the channel your using on the side that blew...
Feb 05, 2010 | Kenwood KFC-W2512 Car Speaker
Amp bass cuts out cuts back on
its a pretty simple principle...combine 2 speakers, and the ohm load gets cut in half. wire them in a series, and the ohm load doubles. for example, you have 2 subs that are 4 ohms a piece. if you combine both + and both - and put them to the amp, it cucts the load in half bringing it to 2 ohms. or, if you connect 1 + to the other speakers =, then run the remaining pair of wires to the amp, that doubles the load to 8 ohms. youll have to "double-ohm" it for dual voice coil subs. on each sub, you can do the same thing. either combine both + and both = into 1 wire to cut the rated load in half, or wire them in a series to double the load by connecting a + to the other coils =, and using the 2 remaining wires. once you have each sub wired the way you want it, then you can use the same rules when connecting multiple subs, by wiring in a series or parallel. it sounds confusing and its hard for me to put into works, but once you do it a few times its really easy. just remember the 1 rule...wire 2 coils parallel to cut the coils load in half, and wire it in a series to double it. hope it helps.
Sep 08, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
I have an alpine mrd-m1001 getting curr message ho do you reset the amp
Hello deeprajm,
Shorted or low impedance outputs can cause the "CUR" display. Power down everything and remove the speaker wires. If it will then power up without the display, the problem is probably a short in the speaker wire or voice coil, or the impedance load is too low. If there are multiple subs, reconnect them one at a time to isolate the bad one and then correct the problem. If the amp works properly with either of the subs but not both, rewire the subs for a higher final impedance.
If the amp still displays "CUR" with the speakers disconnected, there's most likely an internal fault that requires component level repair.
Hope this helps.
Aug 01, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Nothing working! please help!
no it doesnt HAVE to be wired in it just lets you control the amount of output from the sub. however the spark could have blown out the internal workings of the amp. there are genereally multiple fuses on car amps. have you checked these? if they are blown replace and reinstall if not then it very would could be that the spark caused the amp to fry.
Feb 18, 2009 | Kenwood KAC-5203 Car Audio Amplifier
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
1,016 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
