I've tried numerous possibilities with each input but they never show a clear picture.
  • 27 Answers
If the components you are connecting to the tv set are working but the picture quality is the problem, then it sounds to me like you are connecting them to the correct inputs, just your connections or cables don't have a good connection. My visio never gave me a perfectly clear picture (like you see at the store) from my satelite or any other input, until I used an HDMI cable for the connection.
Posted on Oct 31, 2012
Why is there sound but no picture?
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Nov 03, 2015 | Samsung TSL3294HF TV
PS3 wont display using HDMI ports and Input connection on PT-52LCX66
It would seem either a setting at the ps3 or the set is not right.
Good idea to check all inputs and setup again--if something like a DVD works on rear input issue is with the PS3.
Mar 14, 2012 | Panasonic PT-52LCX66 Projection Television
Comp 2 showing instead of video 2 - Picture in Picture
Depending on model number try first to UNPLUG set and turn on again.
Please confirm model number if possible so I can assist.
Mar 11, 2012 | RCA Televison & Video
Picture is only clear on color steam 2 and shacky on every other input diferent equip. have been tryed
Possible that the input logic selector is faulty as there can be a digital gate failure.This can cause the input to be scrambled and so there is loss of sync. which can result in the poor picture. So it is important to trace the input, check using a signal feed to find the switching fault.
It can also be related to a fault in the video board but the fault points to this section as the video signal is clear otherwise.
Sep 27, 2011 | Toshiba 50H81 50" Rear Projection...
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I plugged in the pc with a dvi cable but no pict is showing,in the front pc connection the pict shows but the picture is rather 4:3 or full screen but very bad pict(changing the resolution on the pc)telll...
When you connect the DVI, try hitting the input, source, or conection button on the remote on TV. Some vendors use different names for the button. Use the procedure below to set the resolution for the second screen to 640X480 first, then move the resolution up one notch at a time to see what your TV can handle.
Many televisions don't allow an input through the VGA connector that's a higher resolution than 640X480. That is probably the format that you see appearing on screen where everything looks huge. You may be able to increase from that slightly after getting 640X480 working.
When you've made all the cable connections right-click on the desktop, then choose PROPERTIES from the bottom of the list.
A small window will appear with a few tabs on the top choose the last one, SETTINGS.
Click on the screen shown on this tab with a numeral 2 shown. On the middle-left you'll see a slider showing large and smaller at each end, bring it down to 640X480, then hit apply
A pop-up will appear asking you to confirm that this size is working, click yes if when it does.
Try increasing the resolution by a notch to see if the next size up works with your TV. If you see the Invalid Format on your TV again, you've gone higher than this particular input on your TV will accept.
To get a higher resolution signal you made need to switch to a different cable type, try DVI or HDMI. Either of the two should work more automatically than the VGA cable you are now trying.
If your computer only has a DVI port and the TV has an HDMI port you can get a cable that has DVI at one end and HDMI at the other by clicking here:
May 11, 2011 | Televison & Video
Vb projects
One of the assignments given for a masters
was to provide an input box for english postcodes (zip fer other places) that would filter out ANY invalid input in as few lines as possible.
With entirely numeric that is simple as it is just a string length
but some countries use alpha numeric and the letters have to be in the correct places eg. wf15 9lf or WF15 9LF or W15 would all be valid but W15 9LF would not..
Again minimal code would show an attention to detail because anyone can write a 100 lines of code to do that try get it in 15 or much less and it becomes more impressive
Specific alpha numeric data input and format sorting always seems to go down well with professors.
I havent given you everything to write the abstract bu the bare bones are there and it gives you an idea of the types of thing looked for.
After all if I gave you the whole thing it would not have been your work.
Aug 25, 2009 | Microsoft Computers & Internet
How to set up the color of picture
Keep in mind that this is Hi Def. set and if you are receiving an analog signal the picture is not quality. It will appear snowy or busy and not clear. Do you have a hi def cable or satellite source? If so make sure you are using the hdmi inputs or at worse the component input. Tune to a hi def channel and the picture should be great. If not you may have a problem and then I would exhange the unit from where it was purchased.
Feb 11, 2008 | LG 42LC2D 42 in. LCD HDTV
Picture moved up and to the right
I know this is an old post, but it was never replied to and I just joined the site. Does the image only show the shift when on the DVD input? It is possible that the DVD player is the one shifting the image and not the TV. Try another device on that input and see if it goes away. Kenneth
Dec 18, 2006 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
