Question about Magic Koritech Plus 2005 Microphone
Power on and off
When I turn on the power it will work for 1 to 2 minutes,then it will totally turned off.I tried many times but same thing happen.I don't know if I need to buy new adaptor?
How it solve this problem
Posted on Apr 11, 2009
My computer has one long beep 2 short beeps, I put in new RAM and still does the same.
One, if I may; clean the gold plated contact pins with a pencil eraser, use air to remove the eraser dust. THEN try again before buying new Ram Memory.
(You are Following Anti-Static Precautions, right?)
Unplug the computer from power. Press the Power On button in, and hold for a count of 10 seconds. Let go.
Do this procedure two more times.
Plug the computer back into power.
What this does is clear CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
We are just trying to clear CMOS Error Codes.
WAIT 1 minute, turn the computer on.
Still no?
'Slap' BIOS around a little bit.
Hold the Power On button in for a count of 10 seconds, or until computer turns off.
WAIT 1 minute, turn the computer back on.
I had to do this 3 times, one time, in order to get BIOS to recognize the new Ram Memory.
A) Ram Memory HAS to be in Slot 1. (DIMM 1)
That is the ram memory slot the Processor reads first.
Don't care about the other Ram Memory modules at the minute.
Just want to make sure a module is in Slot 1.
B) Are you SURE you have the correct Ram Memory?
There is a TOTAL amount for the motherboard, and EACH ram memory slot has a Maximum amount also.
Install in Slot 1 first. Try computer. If it works, then install ram memory in other ram memory slots.
No didn't work?
Then install in Slot 2.
You may find one of the ram memory slots is bad.
Regards,
joecoolvette
Feb 28, 2013 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Scurity lock has the engine locked
U can try this to unlock the Passkey security system, if the below procedure doesn't work then the next steep is the dealer.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Mar 29, 2009 | 2000 Oldsmobile Intrigue
M50 SCREEN TOTAL BLACKOUT
i think there may be inverter problem.
Mar 07, 2009 | Toshiba Satellite M50 Notebook
Sansa SanDisk mp3 out of power
Try these:
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 25, 2009 | SanDisk Sansa m240 MP3 Player
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
DVD stuck won't eject
You must unplug the unit from the wall for 1 minute (this allows the unit to reset). Then plug the unit back in but before you turn it on press and hold the eject button and then turn it on, it will eject the disk.
Jan 20, 2008 | Bose 3 2 1 GSX System
TV loses all power
I had same problem. Finally figured out the power supply was the problem. I ordered a generic replacement and it hasn't shut off again for over a year. The only thing I have notice is there are noise lines in the lower channels (1-6). This may be beause the Toshiba power supply may have a noise filter in the power supply. But the generic was $30 compared to $80 Toshiba
Dec 05, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
82 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
