Question about Microsoft Windows Vista Ultimate Edition
All Usb ports not Working
I used have XP before I upgraded to Vista. It was all fine for about 2 months until one day i wen to my computer and inserted my usb. The usb light flashes for a sec then it gone. Like there is no power. My computer doesn't detect a single thing. Nothing abolut anyhting malfunctioning or anything.
Asus motherboard A8n vm csm
700 watt power supply
  • shademon10 Jan 04, 2009
    there is nothing like that my computer see's that everything is working and updated.Even my front panel usb's aren't working. there doing the same thing as the back ones, which are intergrated to the motherboard. Not sure what to do............
  • 42 Answers
First you need to see if your computer recognizes the USB ports on the computer. Right click on My Computer and go to "manage". Select the Device Manager option and at the bottom of the list on the right you should find Universal Serial Bus Controllers. Check to see if your port is listed and if it has an error. You'll be able to tell by a yellow question mark or exclamation point. Once you know that you can finish solving the problem
Posted on Jan 03, 2009
  • word2thewhys
    word2thewhys Jan 05, 2009
    Is it only for USB flash drive or do your ports not run anything at all? Try going back into the device manager uninstalling them and reboot your computer. It should recognize them and reinstall on it's own. See if that helps.
Here is another option: you can see if your computer has even recognized the device by going into the computer management again, accept this time check the "disk management" instead of device manager. You should see your hard drive listed and hopefully your flash drive is there as well. If it is try right clicking on the drive and select "change drive letter..."select something like "x" and see if that helps it to appear.
I know you may not want to hear this, but If this doesn't work you may need to resort to adding a PCI card with some new ports on it.
Jan 06, 2009 | Microsoft Windows Vista Ultimate Edition
restart the computer try that then get back to me
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
Go to Regedit and type the following HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesUSBSTORstart
change the value data from 3 to 2
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
Was having problems with my vx922 lcd display.
Sounds like my problem that I fixed by sending back for repair.
I read that these VX922 monitors are affected by dodgy capacitors on the power board.
I had the monitor for over 2 years. Viewsonic picked it up, yep u guessed it... changed 2 caps on the powerboard sent it back all within 2 days, under warranty. I got my awesome monitor back. Its all good!
Dec 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Dec 19, 2008 | Computers & Internet
Vista Write Protected USB
have your computer reset and reinstall the operating system.. the software is corrupted
Mar 07, 2017 | Electronics - Others
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
Freeagent tools is not working
It is all about pressing the eSata cable into the back of the external HDD hard. I have been working on this all day and I finally figured out this was the problem. Let me know if you need more help!
Sep 02, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Microsoft Windows Vista Ultimate Edition Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
