Question about Lexmark Office Equipment & Supplies
Wont print color
I refilled the color cartridge so it is full, but it will not print ANY color whatsoever!? help? :(
  • Official Brand Answer
  • 3,344 Answers
Refilled cartridges may not work with your Lexmark printer. We don't recommend using refilled or remanufactured cartridges. It might damage your printer.
Make sure to purchase genuine Lexmark cartridges.
Posted on Nov 02, 2012
informatica
  • 1114 Answers
SOURCE: canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Posted on Aug 03, 2007
nitinbabbar
  • 55 Answers
SOURCE: HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Posted on Jan 28, 2008
SOURCE: color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
Posted on Jul 21, 2008
SOURCE: refilled my black ink but my color ink is empty so it wont print
Put everything that you are trying to print.
If you have another black ink cartridge then put that in the color slot.
Posted on Jun 01, 2009
  • 313 Answers
SOURCE: After refilling original HP60XL I get an incompatible ink cartrid
use GENUINE cartrigdges
Posted on Apr 13, 2010
My lexmark 3150 printer will not print anything in color even though the refill color cartridge is completely full
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. But if that doesn't help, I would suggest that you replace it with new genuine Lexmark cartridges.
Aug 26, 2011 | Lexmark P3150 All-In-One InkJet Printer
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Help me with Search ''I am out of color ink but still have black ink. Do you have to have pink, blue and yellow to print. It's showing that my black ink is full but because my other ink is out it wont...
Unfortunately, many inkjet printers require all the cartridges to be present and not empty in order to print anything. An inexpensive solution would be to buy a inkjet refill kit and chip reset utility. (many cartridges are "smart" and require a reset in order for them to think they're full)
Apr 18, 2009 | Epson CX4200 Stylus Color All-In-One...
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
Dec 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Color cartridge wont print
Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Wont print
Hi, yes I have had problems with these HP printers B4 and it was in fact the INK... strange as it may seem, Ya gota have them "Full" as it were. I have "Fooled" it sometimes by removing the cartridge(s) and powering on & of re-inserting them. But eventually always ended up paying thru the nose for the cartridges. I saved a bit by using refilled ones, but I now use printers that have cheap single color ones, eg: Canon i550
Jul 14, 2007 | HP DeskJet 920c InkJet Printer
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
