I have a Mitsubishi WD-57733. I just replaced the lamp about two months ago. Today I was watching tv and the lamp error suddenly came on. I looked at the back of the tv as it was coming on and noticed
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
Ur power supply board or whatever they call it is going out or went out! It happened on mine the same way. Cost me bout 250 for parts and labor to fix! What ****** me off is that i spend 1300 dollars on a tv u expect it to last a long time! Sure isnt like the old tvs! Good luck buddy.
Posted on Nov 01, 2012
SOURCE: Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
Posted on Dec 13, 2008
wppierce65
SOURCE: My Mitsubishi WD-62528 has suddenly developed a
Replaced the lamp.
Posted on May 15, 2009
welcomejee
  • 10594 Answers
SOURCE: standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Posted on Jul 30, 2009
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
  • 8457 Answers
SOURCE: I have had my Mitsubishi WD 65837 for about 6
Take ur warenty repair,problem with ur backlight video board.
Posted on Dec 15, 2009
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
How do i fix a code 18 in my mitsubishi tv wd-57733?
Try with the remote the soft reset: Menu, 1,2,3, Enter.
Dec 08, 2012 | Mitsubishi WD-57733 57" HDTV
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
How to remove and install tv lamp for model wd 57733
See page 62 of this manual. Read the section titled "Lamp cartridge replacement". It has detailed info with pictures.
http://www.retrevo.com/support/Mitsubishi-WD-57733-TVs-manual/id/3124bh436/t/2/
Feb 06, 2011 | Mitsubishi WD-57733 57" HDTV
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
