Question about Canon Photography
Where is the power button for canon eos elan iie?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
There isn't one. To turn on the camera, hold down the lock release button (just inboard of the command dial) and turn the command dial from the "L" position. To turn off the camera, hold down the lock release and turn the dial to the "L" position.
If you need a manual you may download a copy from here.
Posted on Oct 31, 2012
  • ki ship Nov 03, 2012
    thank you so much!
5 Suggested Answers
  • 556 Answers
SOURCE: Instruction Manual Camara Canon Eos Elan 7E
Is this acceptable?
http://www.amazon.com/Canon-EOS-Elan-Users-Guide/dp/1874031487
Posted on Dec 16, 2007
  • 155 Answers
SOURCE: I have got an EOS Elan II E Film Camera (Cannon).
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
Posted on Apr 10, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: problem with an old Canon EOS elan camera
Try an ammonia-based cleaner..but don't get it on the plastic.
Posted on Jun 22, 2009
SOURCE: Sticky shutter blades
Canon EOS cameras manufactured in the late 1980s to early 1990s have an internal foam bumper for the shutter curtain which deteriorates with time, breaking down into an oily black tar. The tar oozes down and gets onto the shutter blades, causing them to stick. This results in the shutter either failing to open altogether or opening too slowly, resulting in blank or unexposed photographs.
cleaning procedure. Take a cotton swab and put a tiny bit of isopropyl alcohol or lighter fluid on it. Don’t drench it - you just want it slightly moist. Rub the tip of the swab on the oily patch, back and forth extremely lightly. You don’t want to apply any pressure, as the shutter curtain is fragile and easily bent and destroyed. Keep lightly rubbing the swab back and forth until the oil is entirely gone. Alcohol is a weaker solvent and so it may take a minute or two of gentle movement to dissolve the oil. Remember to do both sides of the shutter - you’ll have to move the mirror upwards to get the inner side, so don’t get any fingerprints on it. The easiest way to do this is to set the camera into mirror lockup mode (assuming your camera has the ability) and starting the self-timer.
That should fix the camera for the time being. Of course, the foam bumper is still there and continuing to degrade, so you’ll have to do this cleaning every now and again unless you pay to have it replaced. How often depends on your camera. Mine has gone for a year since the last cleaning without problems.
Posted on Feb 26, 2010
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
I have mounted a M42 adapter to my Elan IIe. It only locks up. It worked fine on my Rebel Ti. What is the problem ?
i have some problem with elan 7 when i mounted m42 adapter and manual lens the expouser mode is gonig crazy i have very wrong exposer not one or two step its more one eos 300 canon its allright whats a problem? thanks evryone
Oct 18, 2009 | Canon EOS Elan IIE 35mm SLR Camera
I have got an EOS Elan II E Film Camera (Cannon). I want to know Cannon has camera with a digital body which suits the lens attachment of EOS Elan II E.
Mar 10, 2009 | Canon EOS Elan IIE 35mm SLR Camera
Manual of Instrucctions for Canon EOS 50e
You might try the Canon support site found at http://www.canon.es/
Nov 01, 2008 | Canon Photography
Door will not close
Door Latch can be changed easily.Remove fascia panel screws,and latch cover screws;ease fascia panel forward slightly to enable unhooking of spring.Carefully remove latch and fit new part(£7-50 from Lehhmans at Stoke on Trent.).Do not bend contacts.Refit all screws.Job Done.(10mins)
Aug 17, 2008 | Canon EOS Elan IIE 35mm SLR Camera
Canon EOS ELAN II E built in flash
I cannot locate the parts diagram for the Elan II e but I did find a PDF for the Elan 7. The flash should be very similar, look here;
Canon Parts List
Jan 28, 2008 | Canon EOS Elan IIE 35mm SLR Camera
Need replacement Shutter for EOS ELANIIE
You can order the shutter assembly from Canon or just the 2 blade assemblies if that is the only problem.
The part number for the entire shutter is CG1-3155-000 and the individual blade assemblies are CF1-2763-000 and CF1-2764-000.
Canon's parts phone number is 1-732-521-7230
Please note that the Elan IIe is a very complicated camera, beyond the capabilities of most do-it-yourselfers. However, you may still want to give it a try!
CameraRepairs
Nov 19, 2007 | Canon EOS Elan IIE 35mm SLR Camera
Photography Logo
284 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
