Asko W6231 Will not finish wash and cannot open door
I have cleaned out the plug at front of machine, started machine again, but still not completing cycle and door will not open
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Posted on Jul 19, 2010
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
May 02, 2014 | Asko W6021 Front Load Washer
Door will not unlock after was is complete.
If the filter is clogged, and the machine is'nt totally empty of water, the door will not let open. I suggest you should check the filter behind the small square "door", down on the left side of the front, and clean the filter well if there's something there:)
Oct 06, 2013 | Asko W6021 Front Load Washer
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
Can't open door of ASKO W6883
If nothing else works, the washer door can be opened as follows:
This must only be done in an emergency
if the machine's glass door does not open automatically when the program has finished.
First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose.
Make sure that the main power switch is off and that the plug has been re- moved from the wall socket.
You will find the emergency opener for the glass door in the double sealed bag.
Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
Feb 28, 2011 | Asko W6021 Front Load Washer
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
Mar 06, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
