Red color strip on top of tv screen other small color issues with color. Sony wega tv. Please help
  • 4 Answers
Replace the colour tube that are in the tv and that shows colour
Posted on Oct 31, 2012
SOURCE: Sony Wega 42" LCD KF-42WE610 Color Problems
Check this "blue dot" link. If this is you issue sony will cover it.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KF42WE610&news_id=237
Posted on Mar 23, 2008
SOURCE: sony kdf-e42a10 42in LCD WEGA green screen
my screen is yellow
Posted on Sep 15, 2008
  • 58 Answers
SOURCE: kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Posted on Apr 25, 2009
  • 197 Answers
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
Posted on Jun 07, 2009
vinnyq
  • 157 Answers
SOURCE: I have a KDF-55E2000 Sony Grand VVEGA Color Discoloration
Bad news: The issue can only be solved by replacing the optical block for the TV. This was a defect in the design of this TV. Replacing this part is very expensive (over $1000) and time consuming (need to take whole TV apart).
Good news: Sony extended the warranty for the optical block for this model. They are covering the cost of parts and labor for this TV. Contact Sony to have them refer you to a authorized service center near you.
Posted on Oct 06, 2009
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
Jan 04, 2018 | Televison & Video
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega 42 has red dot on screen.
Is the dot in just one location..if so does it ever change color at all. My first guess is something has gotten into the color display, like a small dust spec. . Or there is an issue with the front panel. If the unit is less than five years old they will look at it on site under warranty.
Jul 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF42WE610 42" turns on and off
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
3 inch red area at top of screen and smaller blue area at bottom of screen
this would need a optical block. there would be no other way to solve this issue
Apr 18, 2009 | Televison & Video
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Fushia Pink color on screen
It depends how many times the LED blinks. Tell me how many and I can read the description on the manual.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
