Question about Vizio Televison & Video
The mute wont go off
Turned tv on and there was no audio. Pushed the mute button and it shows the red around the speaker. Push it again and the mute icon stays red around it. Unplugged the tv to reset it but still no audio.
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Check two things: first does the set have sound with just a DVD etc connected to one of the rear audio/video inputs? Second is check in menu that speakers are not turned OFF.
Posted on Oct 31, 2012
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 42 Answers
SOURCE: green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
Posted on Jun 05, 2009
dsacco86
  • 1077 Answers
SOURCE: stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Posted on Jun 17, 2009
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
Audio problem
look for a button labelled mute
Apr 10, 2014 | Toshiba Se-r0047 Dvd Remote Control
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
No audio with uv10
I have Jensen uv10. I hooked it up and this no sound in a 94 f159 4x4
Mar 20, 2011 | Jensen Car Audio & Video
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
I have a 32" flat screen and i have no sound.
hello. most likely someone pushed the mute button on the remote or went into the menu and into the audio area and turned off the speakers. So. begin by pushing the mute button on your remote and if that does not restore the sound. go into the menu and find the audio area and turn the speakers on.
Feb 28, 2010 | Televison & Video
My speakers on my laptop wont work anymore. The mute button stays red and even headphones wont work when plugged in. When i go to the control panel and go to sound and audio devices, it says theres ''no...
sir try go to safe mode and then remove the sound device in hardware properties in your laptop then reboot after that, boot normal mode then you have new found hardware then install again your sound device.
Feb 09, 2010 | Audio Players & Recorders
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
262 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
