Question about HP Pavilion a600n PC Desktop
Hp pavilion doesnt start - HP Pavilion a600n PC Desktop
  • HP Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Posted on Nov 01, 2012
  • ernie Nov 01, 2012
    Thank you very much for the advice :)
  • Brian Sullivan
    Brian Sullivan Nov 01, 2012
    no problems glad to be of any help
I have a hp pavilion dv9000 & I'm having trouble
sounds like over heating, bad power supply or blown capacitors. you have any computer skills?
Feb 03, 2013 | Computers & Internet
My hp notebook doesnt have audio driver. i wont be able to play music or video. model: hp pavilion dv1000, intel celeron m 1.30 ghz
HI, You can go to the HP website, then click on the link for Support & Download, Then it will ask for the model of your Notebook which is Pavilion DV1000.
Thank you for using FIxya, your high recommendation is highly appreciated.
Sep 23, 2010 | HP Pavilion dv1000 Notebook
My desktop wont turn on it starts up when i plug
Either the tiny plug on the mobo has come off / faulty switch / faulty mobo.
May 11, 2010 | HP Pavilion m7570n (EX331AA) PC Desktop
Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
My HP pavilion dv8000 gets stuck on the start up Can you help me? David
hello dbudnick,,,were you able to solve your hp8000 'start up' problem?
mine was experiencing the same issue....
the method of removing the batt ,,then pressing the on button for
30 sec ,,or more,,,doesnt seem to help....however,,,,sometimes
the pc wont even even get to the Micsoft bootup screen.,,but rather
stall the <F8> or <F10> press DOS Screen..
gpalm
Nov 13, 2009 | HP Pavilion dv8000z Notebook
Hp pavilion dv6000 notebook is not starting after putting into hybernate mode , black screen, all leds on the panel glow, but notebook doesnt boot
Thats the first problem of that model.They first dont want to go out of hybernate mode after that the wifi will not work and after that the video of that computer will be dead.I had like 30 HP Pavilion dv6000 and i just hey them nov but i can repair them.!!!
Nov 10, 2009 | HP Pavilion dv6000z Notebook
Doesnt start up, amber light doesnt come on, blank screen
please your pc in check the smps and cable and other
all check mother board connected socket and
changeing the new cimos power and apply monitor
and start pc
Sep 14, 2009 | HP Pavilion a320n PC Desktop
HP pavilion ze2000 laptop doesnt turn on
Hi there.
Take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> e1bc638.jpeg.
Good luck and thanks for using FixYa!!
May 19, 2009 | HP Pavilion ze2000 Notebook
HP Pavilion ZX5000
Try to check your adaptor/ charger because it might have been the cause of your battery being drained. Your wire might have been worn out. some wires inside might have been cut off. So that is why even you directly turn into AC-DC connection your PC still doesnt work. If it doesnt work replace your adopter.
Oct 31, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion Dv2000
be sure that the ram is in tight, if it is try new ram
May 02, 2008 | HP Pavilion zt1170 Notebook
HP Pavilion a600n  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
