Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
No white color. Intense red, blue color. KV32hs420
There is no white colour when viewing video, cable etc. however the onscreen menu works fine (all the colours are normal).
problem started intermittently and is now permanent. any ideas?
http://futchfactor.com/upload/IMG_4561_450.jpg
thanks in advance
f
Shuttle83
  • 1139 Answers
SOURCE: Red Colour is faded....looks almost purple?
This might be caused by the CRT or by the chroma circuitry. You will need a schematic diagram and a multimeter set to read voltage. The first thing would be to look at the voltages on the CRT socket. With the TV on and the back off, using the schematic measure the voltages on the CRT socket and see if they match the schematic, if they do not (and they wont) find out if the Red Cathode voltage is too high of to low. If too high the red video circuitry might be at fault if too low the CRT might have a Cathode to grid short. In either case power down the TV and with determine if the CRT is bad (using a CRT Tester / Rejuvenator) Run a series of test acording to the instructions of the CRT Tester. This will tell you if the CRT is bad and if it is bad what problem it actually has. Then you may or may not have to rejuvenate the CRT (follow the instruction on the Tester / Rejuvenator) to do this. If the CRT is not bad then you will have to test the chroma video circuitry to see which component is causing the problem.
As you see you will need some equipment to do the job with. and you will have to have a little bit of an electronics background, If you do not have these I would suggest that you take the TV to a qualified TV repair shop for servicing.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 31, 2007
t00nz
  • 4738 Answers
SOURCE: Dsc-f717
Couldn't see them, but if they were black, or distorted, or strange colors, read on. If your pictures looked strange, it's probably due to a defective CCD imager. If so, Sony should fix this for you for free under their recall advisory, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Posted on Nov 20, 2007
leethedeuce
  • 4472 Answers
SOURCE: Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Posted on Sep 14, 2008
mistersony
  • 320 Answers
SOURCE: Sony Handycam DCR-TRV330 Digital Camcorder: choppy hi-motion play
It very well could be a bad drum causing your problem. Be sure that the servicer you select is a Sony trained and recommended service center as they will have the latest bulletins information and training for your camcorder. I just checked on your camcorder and found this bulletin relating to your problem:
Blocking and Choppy Playback (Appears to be a dirty or defective head drum)
Symptoms / Customer Description
Blocking noise in the video during playback. Objects that were taped in motion are choppy.
[Primary Symptom Code: 1330 ]
Cause
Multiple D8 models utilizing the M2000 tape mechanism.
Cleaning the tape path has no effect on improving the symptom.
Solution
Service resolution, clean the point of contact on the video drum where the drum ground arm, ref # 804 comes into contact with the drum assy. After cleaning the point of contact, make sure the drum ground arm #804 is still touching the Head drum
assy.
(Note:After the tape path has been cleaned, the symptom in this issue will persist and lead most technicians to believe that the drum assy itself is defective. Replacing the drum assy complete will correct the problem, but it is not necessary if
the only problem is a dirty contact point on the drum assy from the ground contact.)
So you may not have a bad drum, but only a poor connection. This is why you want a Sony authorized tech to look at it. If you have any further questions, please let me know.
Posted on Nov 22, 2008
zohail
  • 1223 Answers
SOURCE: Colour screen when taking picture - white when viewed
ok it is called CCD Failure
u are Lucky u are covered in Service advisory from Sony it is a manufac defect just see the link and rate me Fixya for help
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on May 05, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
The people are blue and we have no option for changing the colour
the component video cables are switched around. there are 3 colors for video - green, blue and red
two for sound - white and red
make sure you didn't swap the red cables, or swap the blue and red, this is most likely the cause of your issue, check on both the sat box and on the tv
let me know if you require further assistance
Jul 11, 2010 | LG 42LC2D 42 in. LCD HDTV
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
May 06, 2010 | Sony DVP-NS575P DVD Player
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
No color
There are a couple of possibilities.
1) You may have a red, white and yellow composite cable plugged into the red, blue and green slots
or:
2)you may have more than one video output going to the TV - to fix this, you will want to remove one of these video outputs; if you have an s-video and a yellow cable in cvbs, unplug the s-video cable; if you have an s-video and a red, blue and green cable plugged in, remove the s-video cable; etc etc.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
