Question about Intel Computers & Internet
I have intel pentium 4 3.0 Ghz processor kindly tell me which motherboard is available for this processor
    Problem Solver:
  • 8 Answers
Dear Sandeep,
845 series and 945 series motherboard are compatible with LGA 775 socket.
Hope this help:-)
Posted on Nov 02, 2012
glennsmart
  • 818 Answers
SOURCE: Rise in the Temparature & Processor Fan's Speed
Games and graphics place a huge demand on the RAM (memory) and processor. It is for this reason that gamers buy expensive video cards with huge amounts of RAM inbuilt into the card (The cards are almost computers in their own right).
Your processor has to deal with a lot of information when you watch dvds or play games .. it works damn hard ... hence the heat .
Your best option is to fit an additional cooling fan (computer shops have them in stock). Try removing the side of the computer casing to allow more air to circulate. Die-hard gaming enthusiasts add all sorts of extras to their computers .. water tubes to circulate water .... that sort of thing.
Your processor will become hot .. that happens in all computers. It's EXCESS heat you want to avoid. As a general rule of thumb, a processor's ideal temperature is 40 degrees C, though they do go beyond this temperature at times, without adverse effect.
Posted on May 18, 2009
indus3
  • 212 Answers
SOURCE: My Pentium 4 2.4 GHz processor is running at only
in the BIOS-setup, normally you can adapt the bus speed. as it's running at about 400mhz, i suppose it's set to auto. within the advanced system settings, you should be able to set the bus config to manual and then you can choose the appropriate bus speed below.
Posted on Jun 22, 2009
  • 2668 Answers
SOURCE: CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Posted on Sep 06, 2009
Testimonial: "WAIT A MINUTE I NEED ANOTHER REPLY!SO WHAT YOU'RE SAYING IS MY PENTIUM DUAL CORE CAN RUN GRID?"
SOURCE: where can I find drivers for Intel Pentium 4 506,
what you need sir is the driver for your motherboard and not the processor
Posted on Mar 28, 2010
  • 2226 Answers
SOURCE: from where i can download
sound drivers are for motherboards what is your motherboard numbers is it a 478 cpu or 462 cpu without board i can not help you jim
Posted on May 15, 2011
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
(MOtherBOard)
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Sep 13, 2011 | Computers & Internet
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor fits.it
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
http://www.intel.com/products/processor/core2duo/mobile/index.htm
http://www.intel.com/products/processor/pentium_dual-core/specs.htm
Hope this helps. Thanks for using Fixya.
Jul 13, 2011 | Computers & Internet
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
I could use a diagram of the mother board for a Pentium 4 2.4 Ghz processor. I picked one up second hand to replace my old processor
If your processor 2.4 Ghz HT you need socket 478 motherboard,System bus 800.without HT you need 533 FSB Motherboard.You can buy easily.Where you live? I do not know.China are available made 478 PIN mother board.
Mar 18, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
(3.20 - 3.73 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Aug 03, 2009 | Dell (E210882) Motherboard
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
