My LG TV MOD. CF-20D16 AFTER 10 MINUTES TURNS OFF THEN THIS TIME BECOMES SHRTER I HAVE CHANGED THE Cs IN POWER SUPPLY(small size) NO EFFECT I THINK HV POWER TRASISTOR GETS HOT.YOUR SOLUTION REFERS TO
ORDINARY TV
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Only regular sets and older projection sets have that transistor---if you changed or had bad caps in the power supply it may be the issue.
my LG TV MOD. CF-20D16 AFTER 10 MINUTES TURNS OFF  - 10_31_2012_11_58_52_pm.jpg
Posted on Oct 31, 2012
mistersony
  • 320 Answers
SOURCE: Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Posted on Oct 30, 2008
roety
  • 585 Answers
SOURCE: TV turns itself off, and then switches back on with no display
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like an internal TV issue , only way to know is replace the power supply brick.
There are a few boards in the Tv none that are easy to buy, I'll bet you can buy a replacment power brick on ebay for less than $30.
If you do open the Tv look for any capacitors that look bulged or swollen.
example
If you feel good about my solution please click accept.
If you have more questions post them and
I will reply asap
Thanks
Posted on Sep 14, 2009
budmrtn
  • 11361 Answers
SOURCE: 47 Inch LG HD TV -switches itself off and remain off for days
He may be right, LG is used to be called GOLD STAR, which makes junky electronic products, they changed the name to make it sounds better.
You may be able to get parts here: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D+
Posted on Dec 16, 2009
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
  • 222 Answers
SOURCE: Need a new power supply. Where?
Try E-bay
Posted on Jun 06, 2010
Testimonial: "THanks."
Lg plasma tv turns on then off after 5 minutes
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 14, 2016 | LG 50PJ350 50 in HD-Ready TV
What is the defect if my tv turns off while using it
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 23, 2015 | Televison & Video
I got LG 29 INCHES FOUR YEARS BACK, NOW IT IS GIVING A PROBLEM WHEN I ON THE TV ITS OK BUT AFTER SEVERAL MINUTES THE PICTURE BECOMES GREEN AND PICTURE COMES LIKE NEGATIVE IN COLOURS. WHEN I SWITCH OFF
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 27, 2014 | Televison & Video
My tv screen has turned white
Check and replace its T'Con board.
May 07, 2013 | LG 42LG30 42 in. LCD HDTV
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
My LG 42"tv shuts off by it self
hello, The best way to fix this is by opening the back cover of the television set.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
May 20, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 47LC7DF LCD TV problem: after being on for maybe 30 min., the TV makes a single popping sound and then goes off (no LED is lighted on the front of the TC). Within a minute or less, the TV comes back...
powersupply going into shutdown to fix 1problem coldsolderjoint likely culprit fix go over solder jointc in powr supply mod first then hv circut pwe mod should come allway out tv reinstall should fix problem if not exp in elect just goto lg web site order new pwersupply should cost 60 115 bucks tip pts electronics.com save u money good luck shan
Aug 08, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
