Question about HP Office Equipment & Supplies
My pictures are printing out in off colors. The red is coming out pink and is also taking over most of the colors in the picture. I have cleaned the printhead and aligned the printer but that has not worked?
  • mvmatolka
    mvmatolka Oct 31, 2012
    I have replaced the ink cartridges. When i run the diagnostic page the yellow does not show up.
Have you replaced your ink cartridges?
Posted on Oct 31, 2012
jackboy
  • 2985 Answers
SOURCE: Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
Posted on May 11, 2007
Inky
  • 691 Answers
SOURCE: Printer will not use the magenta color
You did not say what the results of the check pattern showed. Were all the lines present or were there some missing?
If lines are missing, follow the instruction in my previous posts for under head cleaning.
If check pattern is good then you may have a problem with a vacuum pipe. You can download a rescue kit for CX machines to help with this problem from tradebit
Posted on Nov 16, 2007
  • 2427 Answers
SOURCE: Color is off...too much red
Your color profile is off
Click on start / printer and faxes
right click on your printer and select properties
click on the color management tabe and selct another color profile
If that dont work
in the printing preferences (propteries) adjust the amout of maganta(red) down a bit to compensate for the rest..
but the problem is your color profile
Posted on Dec 31, 2007
  • 5 Answers
SOURCE: Printer assistance
please change of it's printer driver software
and i think printer going ok
Posted on Feb 14, 2008
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
When I print pictures, they print with a pink tint. But when printing text, it comes out black/normal. How can I get rid of the pink tint?
Try to the clean the nozzles of your color cartridge. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles with the Lexmark X7350. If problem continues, try to insert a different known working cartridge to deternine if your color cartridge is faulty.
Feb 16, 2011 | Lexmark X7350 All-In-One InkJet Printer
My Epson CX4200 is printing pink pictures - help!
try printing the nozzle check page.. you will be able to see which color that is missing... it should have Yellow , Megenta, Cyan and Black... if any one of the color is missing.. try performing head cleaning and after twice cleaning and still no improvement, very high possibility your print head is clogged..
May 20, 2010 | Office Equipment & Supplies
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
White colors come out pink and the wth bal is auto
I replied your question about pink tint noise in picture.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Color ink is TERRIBLE!
I think you are printing on the wrong side of the paper. Try flipping it over when you put it in.
Dec 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
Oct 16, 2007 | Epson Stylus 1400 InkJet Photo Printer
35 people viewed this question
Seeker5211
Seeker5211
