Question about Toshiba Computers & Internet
Kkingdom of Cambodia songs
Kkingdomof Cambodia
  • lucky_dream1
    lucky_dream1 Oct 31, 2012
    Kkingdom of Cambodia i need song him
AOTO CAD VIRUS CAMBODIA
Hello, Don't worry, if your autocad program infected by virus cambodia no need to worry,
because this virus khmer cambodia autocad anti-virus can protect 100% use normally.
Please send your email to me through my private email: (reachsamnang@yahoo.com)
I will send soft khmer cambodia autocad anti-virus protection to you as soon as possible.
Feb 11, 2013 | Autodesk AutoCAD 2010
Bought sim card in Cambodia for my blackberry. I can text and receive texts, but when I make a call to the same number (home, USA, CAlif) it doesnt work. How come I can text the number, but not call?
Derry, if your numbers are starting with 00 and then countrycode then local number, if yes change initially 00 with +, and then try again, if no then edit number and insert + and country code, then try to make a call. if problem persist try to check your call settings for international calls if is not a barred if yes then remove all barring calls, if problem persist try to do factory reset of device.Best of Luck.
Jul 16, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
I need the instruction to set the machine right for sending a fax from Cambodia to Australia or receiving a fax from Australia. I typed number in Australis to send a fax but my friend there did not receive...
There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
I want to know the iriver branch in cambodia.
there is no branch listed but you can try international or any other south asia branch
  • http://www.iriver.com/
Feb 21, 2010 | iRiver E100 Digital Media Player
I buy printer phaser 8560 from online now it's transferred to Cambodia already when i start the printer it load only 25%, it start load again and again after 30 minutes it's show error: 5,004.400 what...
I don't have the error codes but I suspect the problem is 50Hz line frequency, States side line frequency is 60Hz. A power supply needs to be compatible with the type of input power you are plugging it in to. Check the Data plate on the power supply or on the back of the machine and see if it is rated for 50Hz.
If it’s only rated for 60Hz you need a compatible power supply. Hopefully the power supply is the external type. It looks like a black box (or a brick) connected to the cord that plugs into the printer. Just change it with a compatible power supply.
If it’s a internal type it can be changed or modified for 50Hz but finding a technician that can do that work might be hard.
Good luck
Nov 27, 2009 | Xerox Phaser 8560DN Printer
Hi my name Panha and i am from Cambodia.I want to know why when i copy some mp3 go into my phone(model LG KU990)it didn't show anything.I don't know how to fix this problem.I am looking forward to hearing...
Hi Panha, Id say that maybe you have run out of memory space for storing your MP3 files, try deleting some already present or a few pictures/vids, and try again, hope this Austalian helps you in Cambodia. cheers
Nov 05, 2009 | LG KU990 Viewty
Computers & Internet Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
