Question about Frigidaire Dishwashers
My Frigidaire Dishwasher FDB510LCB0 the water won't stop running in. I have to turn the valve off after each load of dishes I do. What could it be and where is it located on the dishwasher.
  • tll237756 Jan 03, 2009
    Thank you.. Where can I find this item at?
    God bless
    Sergeant:
  • 311 Answers
Thats the water valve .its under the dishwasher .its blue ,whtie or yellow .has two wires to it and your house water supply connects to it and rubber hose going up to dishwasher.you can do it God bless ,tom
Posted on Jan 03, 2009
  • Thomas Malailua
    Thomas Malailua Jan 04, 2009
    to buy new valve.you can do it on line or go to local appliance store.to find part on dishwasher please read my prior posting
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Water will not come into tub to start washing dishes
Paul,If this dishwasher has just been installed or there has been some plumbing work done in the sink cabinet. Please check the shut off valve for the water going to the dishwasher. it is connected to the hot water pipe in side on the sink cabinet. if the shut off valve is already turned all the way to the right it is in the closed position. This would mean the water is off. turn the valve to the left to turn the water on.This is very common after new counter tops are installed.Please also check water line going to the dishwasher to be sure it is not pinched
Hope this helps
Nov 10, 2011 | Frigidaire Dishwashers
Frigidaire dishwasher 15 months old. just started not washing dishes very well. set it for high temp wash. put plenty of fresh dishwashing liquid in. the unit goes thru a full cycle. you open the door and...
First I would check to see if it is getting enough water. There is a screen in the water inlet valve that tends to pick up debris. Follow the links Dishwasher not cleaning starting with the video on the water inlet valve.
Nov 05, 2010 | Frigidaire Dishwashers
Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Water won't stop running into dishwaher
go to sears .com,put in your model number,click on parts and it will show you where it is-mike
Jan 03, 2009 | Dishwashers
Water won't stop entering the dishwasher
SOUNDS LIKE YOUR WATER INLET VALVE HAS FAILED,,REMOVE BOTTOM PANEL AND REPLACE,MIKE
Sep 13, 2008 | Frigidaire 24 in. FDBB840DC Stainless...
Frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Jan 17, 2008 | Dishwashers
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwashers Logo
496 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
